6969ronin6969
I fired up the TR3 a couple of days ago (it's got a later TR3A engine in it) and was letting it idle to warm up a bit. After a short period of time I started hearing a tapping/knocking noise and ran over to shut it off. Engine ran less than 30 seconds with the noise.
I pulled the valve cover and everything felt alright. I pulled it up on ramps (with a come-along) and today got a chance to drop the oil pan and see what was going on. I immediately found a couple of pieces of a tab washer, for the bolts holding the big end of the connecting rod to the crank, in the bottom of the pan. Then I grabbed a flashlight and rolled under the car. The first piston (closest to the front of the car) had 1 bolt starting to come out (the other was tight) and obviously missing some tab washer parts.
The engine has been rebuilt at some time in the past (not sure when) and has run very strong since I've had it (~2 years). I started looking at the other con-rods to see what was going on. Here's what I found: all the other cylinders were tight, the 2nd cyl. had the tab washer installed, the 3rd and 4th had regular lock washers, not tab washers. I took out the 2 bolts for the 1st cyl. and the con-rod bearing had a couple of small pits in it. The crank passed the visual and fingernail test.
My thoughts are, since the previous engine builder was inconsistent enough to use locking tabs on 2 cylinders and lock washers on the other 2, is to drop all the half moon parts of the con-rods (cyl.1~4) and replace the bearings, replace the bolts and put locking tabs on all 4 cyl. I'd use Plastigauge when doing this.
Looking for opinions on if others agree or disagree.
Also, should I use locktite of any kind?
Does the bearing just pop out of the half moon part of the con-rod?
How do I get the bearing out of the upper half of the big end of the con-rod?
Anyone have a preference on rod bolts?
A few other items I noticed while in there:
The bolt heads for the rod big ends have "Auto 75" on them, does that mean anything to anyone?
The crankshaft has "010" hand stamped on a flat spot on the forward end, would you assume this means I need .010 over bearings?
Up on the camshaft, between the first and second lobes (again from the front of the car) are the numbers "MC21434" or "M021434". Does this mean something to someone? Factory camshaft or aftermarket?
Any way I can tell the size of the engine while looking from the underside? I rough measured the rods and they appear to be in the 6+" range.
Thanks for reading this far and any advice/info you can offer.
Eric
Eric
