General TR Nautical Heritage
CJD
Just had to share...
Yesterdays task was rebuilding the heater shut-off valve. I rebuilt the TR3A valve a couple years ago, and it was nothing special. The TR2 valve was stamped with a build month of 1/54. When I took the packing out for the shaft seal, it was actually a string wrapped around the shaft and held down with a packing nut. For anyone that has been around boats, this is the way the prop shaft in boats are sealed...using a packing cord. Most plumbing valves from this era use a paper fiber seal.
That just struck me... how, after the big war, on an island, in a country that became great for its navy, many of the ship-fitting companies were likely contracted to build parts for our Triumphs. Thought it was cool!
Maybe it's more common than I thought. The 1960 valve had more of a paper packing instead of string...although that doesn't mean it had not been replaced over its 50 years. All the 1980's and newer household valves I have worked on used a rubber-like packing. I'll check the hardware to see what they have for replacement packing.
Just to be clear, I don't know any different. It's been a long time since I worked on one of those valves, but I thought it had string in it. Which could easily have been replaced as well.
And FWIW, my first car, a 1962 Chevy, originally had a "rope" rear seal somewhat similar to the packing used on boats. I understand the TR2-4 motor did too, when it was built for tractor service. The scroll seal was actually supposed to be an upgrade as the rope wears while in theory the scroll does not.
What did you find in the later valve? I thought they all used "string" originally. Valve packing is still in common general use, although these days it has PTFE instead of graphite.
https://www.wikihow.com/Pack-a-Water-Shutoff-Valve
There were still a number of faucets and valves (outside and basement) in our first home that was built in 52 that had this kind of packing.
Scott
I've dealt with the old rope seals for the rear crankshaft. They are similar, in that they are, in fact, a treated cord. You wrap a single wrap, being careful to cut the joint where the ends of the cord meet. That single wrap is pushed into a fixed sized groove in the block and bearing cap. They are different in that they don't have a packing nut to adjust the sealing, though, like a boat. With a packing nut, if it leaks too much (or too little for a boat), you tighten the packing nut a bit to stop the leak.
Maybe the break in technology was the advent of synthetic rubber for seals? Everything prior to the 60's used rope and packing nuts...while boats, along with some other industries, have stuck to the "old ways". That would burst my bubble, though...I'll stick with thinking our cars have some "nautical" technology built in.
And by the way, Randall...you sure get up early for being on CA time! I'm 2 hours later and my whole family is still sleeping...
60TR3A TR2/3/3A How Authoritative is the British Motor Industry Heritage Trust? Triumph 6
R British Heritage Certificates Austin Healey 32
Lin Rightway Heritage Trimming - Geoff Chrysler Austin Healey 5
Gliderman8 General TR British Heritage Certificate Triumph 16
W Heritage Kit Help Jaguar 0
C British Motor Heritage Certificate Austin Healey 8
wangdango Heritage Trust Certificate ERROR? Austin Healey 25
S TR2/3/3A the heritage of a tr3 Triumph 6
J Time required for Heritage Certificate?? Austin Healey 2
J Time required for Heritage Certificate?? Austin Healey 8
S Jute Installation on Transmission Tunnel - Heritage Trim Austin Healey 9
aeronca65t New SCCA Heritage Solo Class Racing 2
M Heritage Motor Certificate for Frogeye / Bugeye Sprites ? Spridgets 4
P TR6 Heritage certificate Triumph 4
P TR6 Heritage Certificate Triumph 5
C Heritage Certificate Interpretation help, please Austin Healey 13
S Got my Heritage Certificate Spridgets 2
T Heritage Carpet and padding for 100 Austin Healey 10
drooartz Heritage Certificate for the Bugeye Spridgets 0
J Got my Heritage certificate but nothing new came on the sheet British Motor Corp 2
Rut Heritage certificate Spridgets 19
K Midget "Heritage" Body Shells? Spridgets 2
drooartz Correcting a Heritage Certificate MG 6
D Heritage Upholstery & Trim Austin Healey 26
H Heritage tonneau for BJ8 Austin Healey 0
S BMIHT Heritage Certificate Article Austin Healey 4
Stinger Heritage Certificate Payment Triumph 10
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
richberman Anyone live near Heritage upholstery? Austin Healey 2
Robert560 Premier Heritage Certificates Austin Healey 8
longbridgehealey Got my Heritage Certificate today!! Austin Healey 12
B Heritage interior BN7 Austin Healey 10
C Another side of MG's racing heritage MG 0
smaceng Heritage Certificate Spridgets 3
S Heritage Motor Dvd Triumph 9
mgbmedic TR2/3/3A Heritage Trust Certificate for TR3B Triumph 27
jdubois Heritage Motor Centre CDs Triumph 28
S Heritage Report for my 56 MkI Saloon Jaguar 4
W Heritage Trim BE door panels Spridgets 0
J Installing Heritage Seat Kit - Bottom Cushions Austin Healey 6
R MINI is applying for heritage status in MALAYSIA! British Motor Corp 2
Geo Hahn TR4/4A ISO 64 TR4 Owner with a Heritage Cert Triumph 1
J MGB MGB "Heritage" hood MG 10
C Heritage carpet Austin Healey 19
Rob_T Heritage Certificate Triumph 8
S Heritage Certification Triumph 51
S New Heritage Shell Spridgets 9
Aldwyn British Motor Heritage Certificate: Other Numbers Triumph 5
Lin Heritage Interior Installation Austin Healey 5
Sarastro Got my Heritage Certificate today Spridgets 19
