miss under acceleration after warming
emann
Diagnosing engine problems is definitely NOT my strong suit.
My BE's been running fine for most of the summer.
Then I took it to its 1st car show.
Now, it seems to run fine until it warms up. Then under just slight acceleration, it starts missing. It continually gets worse for about 10 minutes. Then it's sputtering so hard, I'm putt-putting down the street and have to pull over.
If I pull over and sit for a minute, it gets a little better for a few minutes and then putt-putt again.
Am I looking at an ignition issue? Timing, points & condenser, coil?
The coil has always gotten hot to the touch. Is that normal?
Plugs are new this summer. Everything else is 20 years old (but very low mileage /bcforum/images/%%GRAEMLIN_URL%%/smile.gif )
I'm thinking of buying all new ignition stuff (points, condenser, coil) and putting it all in and seeing what happens. But any pointers to get me going are greatly appreciated.
TIA,
Ed
jlaird
Go for it, let us know result. Sounds like coil failing as well.
I'm going to guess... that the valves are improperly adjusted.
glemon
I had a bad condensor on a Sprite once that exhibited similar symptoms. However, that was the only time I have ever had a condensor go bad, so I would not bet on it.
Lucas actually makes an ignition fault finding guide that takes you through the steps of testing all iginition components, I think Moss and others sell it, one use makes it worht the $12 or so it costs.
drooartz
I had a similar issue with the Tunebug, and it turned out to be due to bad plug wires. I wasn't using the proper type, and they weren't getting a good spark to the plugs. Replaced them with proper solid core wires, and the trouble went away.
emann
emann
Thanks for all the help so far.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Replaced them with proper solid core wires, and the trouble went away.[/QUOTE]
Are the ignition wires that Moss sells solid core?
racingenglishcars
I have seen way too many bad condensors to that trick.
A bad coil can also do it, (like my Land Rover did last summer) but I would start with the condensor. Plug wires tend to fail on cold wet mornings and not so much after warm-up. Resistance wires aren't bad, just that they have the problem of... well resistance. That can help marginal insulation to become bad. Too tight valves could also definately be a problem.
jlaird
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif All those things.
Sarastro
If the coil is getting hot, something is definitely wrong. You need to have an "internally ballasted" coil--should have something like 3-4 ohms of resistance. If it has less than that, you have the wrong coil. You could add a ballast resistor in series with it, but probably getting the right coil would be better. The coil may be failing because of the overheating.
MikeAH100M High Temp Engine Miss Austin Healey 2
V MGB Mystery fastener from '66. Did I miss something? MG 6
jlaird Miss Spridgets 3
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
jlaird Name the new Miss Agatha Spridgets 1
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
H Miss Eva Traveled to Cars and Coffee on Saturday Spridgets 7
S TR2/3/3A this little miss in the engine Triumph 17
S TR2/3/3A little miss problem Triumph 12
PC Morgan fans - how did I miss this? Other British Cars 2
Flash_Harry MGB Fixed a miss! MG 7
H Richmond VA 1960 Bugeye Bringing Miss Eva back to life. Spridgets 453
GTP1960 TR2/3/3A Self canceling turn signal, "hit or miss" Triumph 1
W Miss Agatha on the market Spridgets 13
jlaird Where in the world is Miss Agatha? Spridgets 24
jlaird Miss Agatha Spridgets 14
jlaird Miss Agatha jumping up and down Spridgets 0
jlaird Miss Agatha has a new price Spridgets 45
jlaird Miss Agatha not sold Spridgets 3
jlaird Miss Agatha Spridgets 8
jlaird Miss Agatha's build photos Spridgets 1
Bob McElwee Miss BT has a new home [probably a new name too!] Austin Healey 1
N Miss when when accelerating Spridgets 12
69sprite New trailer - Did I miss the mark? Spridgets 8
S TR2/3/3A Bad fuel perhaps water tr3 miss Triumph 0
jlaird Miss Agatha Spridgets 6
scoutll Miss Chuff is Gone - A Midget Owner, I am Not Spridgets 16
V 1275 slight miss, what's the cause??? Spridgets 20
hondo402000 TR6 TR6 Developed a Miss Triumph 7
jlaird Miss Agatha got out today Spridgets 2
jlaird Miss Agatha had a visitor Spridgets 2
DNK Did I miss this??? MG 1
O TR2/3/3A TR3 Engine Miss Part 2 Triumph 11
O TR2/3/3A TR3 Engine Miss Triumph 5
JPSmit Miss Triss met a relative tonight Spridgets 2
Tim Tucker TR4/4A TR4 High RPM miss Triumph 18
jlaird Miss Agatha got out Spridgets 0
jlaird Miss Agathas adventure Spridgets 4
jlaird Was in the garage getting Miss Agatha Spridgets 4
jlaird Miss Agatha Spridgets 5
saysprite Healey 100 in Miss Marple: The Secret of Chimneys Austin Healey 3
jlaird Miss Agatha was trying to tell me something Spridgets 4
longbridgehealey 100-6 has a miss when accdelerating Austin Healey 16
jlaird Had Miss Agatha on the road Spridgets 1
jlaird Miss Agatha status Spridgets 0
jlaird Miss Agatha is the only one Spridgets 15
longbridgehealey very slight miss Austin Healey 3
scoutll Miss Chuff hangin' out with her new Posse Spridgets 7
jlaird Miss Agathas Dizzy Spridgets 7
