Might As Well's
kyreb1862
During the process of removing my starter for its trip to the hospital I have stumbled onto the dreaded "might as well's". I thought since I was already under the car that I might as well take a look at the transmission mounts. Bad idea. The mounts have the consistency of old jello, same for the stay rod mounts. Isn't that the way it always works? You fix one thing and something else is waiting. As my dear wife always reminds me, "Don't get to excited, the car is 31 years old." My question is, how big of a pain is it going to be to pull the transmission member and clean and repaint it and change all these mounts and bushings? As always any input is appreciated.
Regards John
ronzet
John,
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]My question is, how big of a pain is it going to be to pull the transmission member and clean and repaint it and change all these mounts and bushings? As always any input is appreciated.
[/QUOTE]
The job in itself is not a major one... The biggest problem that I have had is access to a scant few of the miscellaneous nuts and bolts once you have embarked upon the re-installation... There is not a lot of room for a wrench. Most of the time will likely be spent turning a nut 1/10,000th of a degree, only to reset the wrench to move it another 1/10,000th of a degree...:wall:
What I might suggest, however, is to remove the drive shaft and <span style="font-weight: bold">carefully</span>avoiding too much stain on the motor mounts... lower the tranny tail end until you have free access to the tranny mounting bolts and install the member with the new mounting rubber to the tranny and then raising the cross member, along with the tranny, back up into position and lastly re-bolting the cross member to the chassis... Has worked for me... But then, you probably thought of doing that already...
The other consideration is, as you said, the 'might as well' schtuff that you will find as you lay prone under the car.... :rolleyes:
Platinum
Ron's method is as good as it gets. And a 1/2" and 9/16" "GearWrench" are nice to have.
If the mounts are goo, you have leaks... but if ya DON'T look up while you replace the mounts and pads, mebbe you won't be blinded by the "Might as Well" Monster! :wink:
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
davester Help me make some engine teardown/evaluation/might-as-well decisions please. Spridgets 6
Steve This might go for silly money... Rover / Land Rover 1
waltesefalcon It might be sacrilege ... Other British Cars 4
RickB Anyone doing a steering wheel swap - a little loctite might be a good idea Spridgets 2
D Might be returning to Spridgets... Spridgets 5
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
H Think This Might be Part of the Problem? Austin Healey 3
JodyFKerr Wedge I might have let the smoke out [TR8] Triumph 25
Randy Forbes It might be a slug, but it sure is pretty... Austin Healey 28
6 might as well syndrome Triumph 11
DNK Might be worth a spare one. Triumph 7
JPSmit You all might be interested MG 0
G You might think I'm nuts, but I'd rather drive... Spridgets 14
D This just might get me to buy a Spridget...... Spridgets 12
C This might be a dumb question but.... Spridgets 15
Thor Any idea what this sound might be from motot Spridgets 9
RickB Bugeye might be available - value question Spridgets 8
YankeeTR You guys might enjoy this... MG 16
prb51 You might be a car nut if.... Triumph 39
F What a Healey might be Austin Healey 27
jlaird Thought you might like to see what I Spridgets 29
jaegzie What might be a desirable serial number be on a BE Spridgets 13
T Today might be the demise of the Crypt Car Triumph 19
T I might buy another Triumph! Triumph 14
bluemiata90 I MIGHT NEED THERAPY Triumph 13
jlaird Thought you all might like these. Spridgets 24
Trevor Jessie Might be a little quiet here for a few days Spridgets 24
regularman I believe a blind man, might be able to see my... Spridgets 14
G Spitfire 1971-80 Spitfire owner's might be interested. Triumph 1
bravenrace Might be a World Record - Where's Guiness? TVR 3
jlaird YOU MIGHT BE A SPRITE DRIVER IF. Spridgets 26
T Wedge Nice TR8 at Cars & Coffee - might be for sale Triumph 0
19_again Head gasket--might as well? MG 7
jlaird Thought you all might Spridgets 1
gsalt57tr3 looks like, smells like a scam, might be a scam Triumph 7
TR4 Might be nice ....... Triumph 5
jlaird Thought you might like these Spridgets 3
jlaird Thought you might Spridgets 10
Steve Might do somebody some good.... Triumph 2
J thought you guys might like this TVR 2
6 Thought some of you might like to see my Sprite Spridgets 40
regularman Important question [I might have just screwed up] Spridgets 8
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
budk1953 You might want one British Motor Corp 9
ahpook This might be a sin, but Spridgets 7
YankeeTR You might enjoy some of these pictures... Triumph 8
