TR2/3/3A Metal washers for SU H6 float bowls
jfarris
I have a leak on the lower connection of the float bowl and carb body, rear carb only. The rubber seals appear to be Vitron. Looking at both carbs. The lower washers appear to be correct, approximately the same size as the flange they mate to. The upper washers are not the same as each other or the lower washers. One is copper and similar to an oil plug crimp gasket, smaller than the Vitron seal and the other is aluminum and about the same size as the vitron seal.
What should these four washers look like?
Thanks
Upper washers should be the same as the lower ones. Not Viton usually, but something similar.
The stock seals don't last very long in my experience, so I'm guessing what you are seeing is a previous attempt to find a longer lasting solution.
TRF will sell just the washers (aka grommets), if you don't want to buy the kit.
B Is the rear edge of the Bugeye bonnet sheet metal supposed to be bent inward? Spridgets 2
G For Sale TR3 original metal air filters Triumph Classifieds 0
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
D Made a sheet metal break. Restoration & Tools 5
J Door Draught Metal Clips Austin Healey 4
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
F Off Topic metal forming for a friend Triumph 25
N Spridget sheet metal Spridgets Classified 0
steveg TR6 Metal Dash - does anyone make one? Triumph 13
J For Sale Triumph TR 2/3MISC sheet metal parts Triumph Classifieds 1
Busted knuckles TR2/3/3A Sheet metal question, Triumph 5
F TR2/3/3A Rear sheetmetal repair Triumph 73
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
red57 Metal prep of chassis after repairs and shot blasting Austin Healey 5
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
S TR2/3/3A busted through to bare metal Triumph 18
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
SpeedyG TR4/4A TR4 vs. TR4A metal dash panel Triumph 5
S TR2/3/3A were the 2 metal gas lines connect Triumph 18
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
S TR4/4A Metal facia trashed Triumph 3
R metal adhesives Austin Healey 12
Editor_Reid Metal [or maybe fiberglass] tonneau for Healeys Austin Healey 24
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
C Recommendations on where to send my 1954 BN1 for metal work? Austin Healey 13
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
I General TR Pot metal rechroming Triumph 7
T TR2/3/3A Requesting some Pictures for metal work Triumph 9
MTribe TR6 Can you identify these metal shavings in the oil? Triumph 32
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Brinkerhoff MGA metal work details MG 18
X sheetmetal needed Spridgets 1
certifiedcarnut Spridget master cylinder cap, metal Spridgets 8
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
Scot1966 TR6 TR6 sheet metal Triumph 3
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
JPSmit New fun tool review - metal tumbler Restoration & Tools 6
R Simple question about metal Spridgets 18
Hap Waldrop King Tri metal Bearing MG 10
doc50 Best Method to weld sheet metal repair panels in... Triumph 10
Willie_P TR4/4A Moss Replacement Sheetmetal - TR4 - any good? Triumph 6
S TR2/3/3A tr3 metal fuel lines Triumph 1
J aftermarket sheetmetal Spridgets 2
L Bugeye door pocket metal trim Spridgets 0
