catfood
Hi folks,
I'm hoping someone might be able to suggest where to look first with an igniiton issue I have just encountered.
My BN1 has been converted to negative earth, has an alternator and CSI distributor.
I was tweaking the carbs and everything seemed to be running smoothly at tickover. I switched off the ignition while I looked for my carb balancer. When I restarted it the tickover was really rough and it struggled to keep running. Applying the accelerator had no effect. I switched the ignition off to check everything over and went back to restart it and it was the same. I switched the ignition off and the engine carried on running. I had to block the carbs to stall it. At his point I noticed the ignition light was still on even with the key was removed. I tried turning the power off at the boot (trunk) switch and the ignition light was still on. In the end I had to disconnect the battery to switch it off.
So any one encountered this before. Any suggestions?
Cheers
Steve
Cheers
Steve
