TR4/4A Looking for piston & liner recommendation
AHS
I've just removed the pistons & liners from my TR4, 2 of which are seized from 30 years of storage. So it should get a new set of pistons, liner sleeves & rod bearings and be good to go. It's 50K miles, and the crank journals all look & measure perfect. I'll probably install a 87mm set.
Anyway, does anybody have recent experience, good or bad, with piston & liner sets from the various vendors that they'd care to share? I'm finding conflicting info searching here. One post says Moss sells AE brand and are 3 ring, another post says they are unmarked and 4 ring. TRF sells "County" brand. I've heard of one piece and three piece oil rings. I'd appreciate hearing what brand or vendor's product has worked for others.
Another odd question, are the #2 rod bearing shells supposed to be grooved, and the other 3 sets are not grooved? That's what I found. There are no signs this engine was ever apart prior to today.
Thanks,
Andy
Last that I heard A&E piston and liners are no longer available. Several years ago I bought a set from TRF that I believe were Mahle. The only other brand that I have seen is County. I recently bought a County set from British Parts Northwest.
I just looked at a set of NOS A&E rod bearings and they have NO GROOVE. So I would guess that your #2 set is a replacement. My best guess.
Charley
The nonconforming rod bearings are a high level sign the engine has been apart before. A call to Moss or TRF will probably get you the skinny on the piston stuff.
Bob
I used the 86mm set from Moss about 2 years ago. I do not recall any brand on them, they appear to have 3 rings.
So far everything seems fine.
Repeating from an earlier thread. Years ago, (decades?) I rebuilt the engine on my then TR3A. Being a poor student, I bought Vanguard pistons and sleeves which were cheaper than TR ones. They were 85mm, giving 2088cc and they had 3 rings above the gudgeon and another oil ring below the gudgeon. I was later told that TR pistons had only 3 rings, all above the gudgeon, to give greater oil supply to the pin. Presumably, TRs were expected to be revved harder than Vanguards, and the owners were more likely to accept a slightly greater oil use. I assume that 3 rings also gave less friction and thus more power than 4 rings.
My current 4A has 87mm Mahle pistons and liners and has 3 rings. It has done 20,000 miles since the rebuild and only uses 500ml in 2000 miles. Like Hansel and Gretel, some of that goes to leaving a small trail so that it can find its' way home........:friendly_wink:
Thanks all. I'll ask Moss for specifics on what they supply today and let you know.
Andy
People in our club have rebuilt 4 of these engines in the last two years. 3 out of 4 had problems with the 3 piece oil ring not sealing. The cars burned oil, which you could see come out the tailpipe. The one car that did not burn oil happened to have a Hastings type oil ring which was one piece. The curvy spring on the 3 piece broke at the ends, but I still can't see how that affected the scrapper rings top and bottom to cause the oil burn problem. These three cars had the rings replaced by Hastings brands and all is well now.
Jerry
Thanks Jerry, that's very useful information. I've no answer from Moss yet but I see they do sell Hastings rings separately. Perhaps I'll buy their piston set and pitch the rings that come with them for as little as the Hastings rings cost.
Andy
Andy,
Just for the record the set of pistons and liners that I got from BPNW which are County ( name is on the underside of the crown) are three ring and came with a a set of Grant rings.
Charley
I am pretty sure the oil rings from Grant are those we had problems with. Do you have a picture of the oil ring?
Jerry,
Here are the pictures I have of the oil rings. I also bought the 87mm piston/liner set from BPNW and they do indeed come with Grant Rings. I'm having my engine rebuilt by Del's up in Sacramento (recommended by PatGalvin here on the forum) so if I can save myself from issues I will go with Hastings. I do notice on Hastings website they have three ring ones as well. Do you know which Hastings rings the people used that had issues had replaced them with? There seems to be four types. Also, they sent steel figure 8's but I've heard it's better to use the copper. I do have a set of those that came with my engine gasket kit. Should I use those? Thanks
Info from Moss is that 86mm & 87mm sets they sell are both County brand and come in the door with Grant rings. Hastings rings are available separately but they only have the 86mm set, the 87mm set (or 86mm+.040" over) is not available any longer through them. Perhaps it is available other places. 86mm is fine with me so that's what I'll do. Thanks Jerry, you may have saved me from creating another oil-burner.
Andy
The Grant rings are as shown in Gary's pictures. I will as well look for some Hastings rings before I use the Pistons.
Thanks ,
Charley
FWIW - I had no problem using the rings supplied by Moss (I think they were Grants). They were the ones with the different colored ends (red & green?) that have to be installed with no overlap - hence the colors to make it obvious if you screw up.
Here are a few pictures for everyone showing the 2 86mm ring sets & pistons I just received. Charley, perhaps the part number will help you locate the similar 87mm set. I'd have done 87mm if the Hastings rings were easily available.
Notes:
-The hasting oil rings are 3pc like the Grant. the notable difference is the tighter serpentine pattern on the Hastings. They both look OK. It might be possible that the problems some others have had with burning oil with Grant rings is the sealing of #1 and #2 rather than the oil ring. But that's speculation. I'll go with Hastings since everyone seems to have good luck.
-Pistons clearly say "COUNTY" inside the skirt and do have steel plates in the sides
-Groove depth is .170". The ring widths are in the engine data & printed on the Hastings box so no sense repeating them.
Andy
Our rings that had problems were from MOSS and the pictures above show them. They must work, but we had engines that blew smoke and when we took them apart, the ends of the oil rings were broken. These rings were fitted into the cylinder for size prior to installing so we don't know why the break at the ends, but the cars blew smoke and required oil addition. After about 600 miles, we gave up and installed the hastings brand of oil rings. No more problems.
Jerry
Thanks ,
Charley
Charley,
Should you find a source for the Hastings can you PM me and let me know where you found them? I'd prefer to have a piece of mind even though the Grants may be fine. Thanks
Gary
Gary,
I have the 86 mm piston set. I decided that the 87 mm set didn't do all that much more and it just made the gasket that much narrower against the water passages and therefore increased the possibility of a head gasket leak. I am likely about six months away from getting to the engine. It looks like the set in Andy's picture is for a 86mm . With that number I should be able to go to the local car parts store. I'll let you know what I find.
Charley
L TR4/4A Looking for a TR3-4a 87mm piston & Liner Triumph 0
Z TR6 Looking for one .060 TR6 Piston Triumph 18
V Looking at a Grantura TVR 17
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 5
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
