Looking for a zinc plater for a small job
jlaird
In fact the top of a windshield wiper motor. I know, but mine looks bad and show season will be upon us before too long and wife asked what I wanted for Christmas.
HELP :greedy_dollars:
Hey Jack this looks like the ticket for the job you are wishing to do. Video seems pretty simple. Let us know how it works out for you.
Caswell Plating has a kit too.
You can do it Jack!.....and I can watch.:grin:
I've used the Eastwood kit. Don't bother with the d cell battery power it came with, I used an old toy train transformer so I could vary the power, more for bigger pieces. Worked great, dip it in the solution for a couple minutes and a light buff with steel wool to knock down the slightly rough finish. I've used it on brackets, bolts and all sorts of small pieces. One thing to note though, the piece has to absolutely clean with no grease, dirt or especially small pockets of rust. The process accelerates rusting so a dip in the solution with power will leave rust circles where it wasn't clean.
So is Electrolytic Rust removal a possibility to do before you go on to this process. Thinking about small pieces where sandblasting may not be a possibility.
Jim,
you can use electrolytic rust removal prior to plating, but they have the same limitations from what I understand. If you have parts with small internal cavities both processes will have a hard time reaching those places. An acid bath where applicable might get to those places. Once clean and rust free you should not have a problem plating the part. I also understand that heating the solution can make it more effective. I do this when I blue parts and it makes a big difference. I also use distilled water to keep contaniments from making it 'splotchy'. You may want to get some grease free oooo steel wool to card the part between platings.
good luck, Rut
'Round here we usually put the plates in the zinc, not the other way around daw'lin.
(Bill and Mick no what I'm talkin' about.)
I did try the do it your self method, does not hold up over long term. Does look great for 6 months or so.
I'd suspect that prep of the parts, depth of the zinc and direct weather exposure play a part in how long a home job will last. The brackets and bolt and such I've done over the last several years all still seem good, but they're not really exposed to the outside either.
V Looking at a Grantura TVR 17
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
Michael Oritt Looking for a good 100 crankshaft Austin Healey 5
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
