TR2/3/3A Link Rod Lengths Accelerator Linkage
mgedit
Can someone tell me if there is a standard length to which these 2 rods should be set? In Figure 10 under Fuel System in Service Manual they are identified as Long Link Shaft Assembly and Short Link Shaft Assembly. I believe in the past I just adjusted them so that they fit into the appropriate levers in the "at rest" position. Is that how it should be done or is there a specified standard length? I can't find any reference in the manual to indicate how they should be adjusted. If I missed it I apologize, but would appreciate a redirect to the information. Cheers, Mike
I don't believe there is. Too much variation in bodies and frames and how they sit relative to each other.
I start by setting the lever on the front carb so it makes about a 45 degree angle with the first rod, with the throttle closed. Then set the short rod so the bell crank is at 45. Check for free motion throughout the range. Then set the long rod so the pedal just hits the stop (or floor) when the throttle is fully open.
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
B TR4/4A Headlights Blink Off Triumph 15
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
D MGB Rear Suspension Damper Link Arm MG 2
banjojambo Triumph tr3 vertical link wobble Triumph 2
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
V TR2/3/3A Vertical link check Triumph 2
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
S TR2/3/3A Vertical link Triumph 3
S TR2/3/3A How bad is this? Vertical link Triumph 12
J TR2/3/3A L/S Vertical Link Resistance Triumph 17
N Watts Link??? Spridgets 2
H broken sway bar link - again Austin Healey 8
T TR2/3/3A tr3a verticle link removel question Triumph 11
G BJ-7 Rear Shock Link Austin Healey 2
B Support bracket for the rear suspension damper link Austin Healey 5
D TR4/4A stubborn lever shock link Triumph 2
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
glemon TR5/TR250 Turn Signal Wont Blink Triumph 1
N Top link offset bushings?? Spridgets 6
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
mcmillal TR4/4A Broken Vertical Link Triumph 17
T TR5/TR250 250 Sway Bar Link Triumph 0
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
T Perished Rubber/etc on BE rear shock absrober link Spridgets 0
DornTRoriginal TR2/3/3A Horizontal Link Assembly Install Question Triumph 1
J TR2/3/3A Need a TR3 vertical link Triumph 1
D TR2/3/3A Vent lid link length Triumph 8
J TR4/4A 67 IRS Damper arm/link removal help Triumph 10
S TR4/4A Reversing upper fulcrum link Triumph 3
B Parts for sale on Panjo link Austin Healey 0
M_Pied_Lourd TR2/3/3A Verticle Link to Trunnion Fitment Triumph 5
K Jaguar 140 Restoration Link? Jaguar 2
Morris OOS Upper Link Spridgets 6
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
K TR2/3/3A Silent bloc bushings in the drag link. Triumph 2
BobbyD Off Topic HiJacked Forum Link? Triumph 4
aeronca65t MGB Excellent MGB info-link MG 0
blueosprey90 MGA An Alternate Sway Bar Link for the MGA with MGB Sway Bar [ a repost] MG 1
drambuie Check out this Healey 100 with a Jag V12 convertion [click on the british v8 link] Austin Healey 5
H broken sway bar link Austin Healey 13
TimK How do you post a link to an older post/thread? Austin Healey 4
T TR2/3/3A TR3B vertical link Triumph 13
K Link to pic of 4 inner sill install without floor? Triumph 0
T Help on ball joint - vertical link fit Triumph 20
drooartz Shaka shaka plink, shaka shaka shaka plink... MG 8
