Hydraulic Shock Fluid - Bilstein Shock Conversion
stretchit2
I'm installing my Christmas Present...... Putzke's Fahrpass Bilstein Shock conversion kit. Pretty easy task but there is one thing I didn't plan ahead on, I did not plan for refilling the oil in the original equipment shock.
The installation calls to remove the oil plug and take the valving out and then refill with oil. Moss sells hydraulic shock absorber fluid, but I can't (or won't) wait to have it delivered. So here is my question, can I purchase an oil at a local auto part store? If so, what would be appropriate specifications?
Keoke
ed. So here is my question, can I purchase an oil at a local auto part store.
I would think so.However, I would ask Putzke to be sure that the brand is compatible --Keoke
BoyRacer
You need shock oil and your local auto parts store will not even know what you are talking about. Go to a motorcycle store and buy some "fork" oil. A popular brand is Bel-Ray and I would recommend 20 wt oil for your '61 3000.
stretchit2
stretchit2
Boy Racer
Thanks for the tip!
Happy New Year
PeterC
Since the oil wont be doing any hydraulic work, it can be any old oil you have laying around. All they are doing is lubricating the non-existent bushings, and having some slosh around in the cylinder bores. 90weight gear oil would be the best, probably, but anything will do.
Peter C
BoyRacer
Peter,
You are correct. I spaced out on the first paragraph of the initial post about removing the valving because of the conversion to tube shocks, and instead, focused on the second paragraph about where to find correct shock oil.
Jerry
You will like the conversion. My BJ8 rides better than my wife's Toyota. It is a nice upgrade!
Jerry
BN4
BJ8
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
JimLaney hydraulic line material Spridgets 6
J Hydraulic Brake Switch Internals Austin Healey 19
I General TR Hydraulic lift opinions/info needed Triumph 34
C Bleeding the hydraulic clutch Spridgets 6
Lukens TR2/3/3A My theory about my clutch hydraulic problems Triumph 11
Lukens TR2/3/3A Clutch hydraulic problems Triumph 12
M 948 clutch hydraulic line Spridgets 7
W Hydraulic Tank Austin Healey 8
catfood Hydraulic cylinder repair. Restoration & Tools 2
texbears3 TR4/4A Hydraulic Fluid Contamination Triumph 10
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
GBRandy Wedge TR8 Hydraulic lifters - Replace? Triumph 1
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
Lin 4-post lift hydraulic fluid Austin Healey 5
TulsaFred Hydraulic system disassembly-reassembly Spridgets 10
M TR2/3/3A TR3A Hydraulic system problem Triumph 4
Moseso Weird Hydraulic Failure Triumph 8
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
M Hydraulic Problems Spridgets 5
I Bugeye hydraulic problems Spridgets 9
JohnnyMead Another Hydraulic Fluid Reservoir Question Triumph 10
angelfj1 Paint Quality - Hydraulic Fluid Reservoirs Triumph 14
R BE Hydraulic Question Spridgets 15
Ohiobugeye Another Clutch Hydraulic Line Question Spridgets 2
ekamm New hydraulic resevior Triumph 5
Ohiobugeye Got Engine Running, But have Hydraulic Leak Spridgets 2
Ohiobugeye Hydraulic Bleeding Sequence Spridgets 7
F Dirty Hydraulic Fluid Austin Healey 7
bluemiata90 CLUTCH HYDRAULIC HELP Triumph 9
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
S Hydraulic Brake Switch Austin Healey 5
knad2208 Hydraulic Clutch Fluid Spridgets 1
F Hydraulic clutch adjust Triumph 9
Tinkerman Brake and Hydraulic lines Triumph 4
S hydraulic lines to seal Triumph 4
philman hydraulic lifters Restoration & Tools 5
M Hydraulic brake light switches Jaguar 2
Shinsen774 T-Series Hydraulic Brake Switch-Early MGB-Still a problem? MG 9
Baz Teflon tape on hydraulic lines? MG 7
mrsprite Clutch hydraulic woes Spridgets 32
G Bleeding the hydraulic clutch Spridgets 36
martx-5 Clutch Hydraulic Pipe Routing Triumph 5
regularman British brake hydraulic fittings? Spridgets 9
71tr clutch - hydraulic throw out bearing Triumph 13
