doates
Hello All,
I have been lurking here for a few months but this is my 1st post. I have a 70 Spit that I am finally resuming work on. Getting ready to put the interior in after a 4 year long body off restoration.
I tried to take it out for a putt around the block to make sure that the transmission (that I rebuilt) actually worked. I am glad that I did because I can't get it to shift into second from either direction. 1st and 3rd work fine but when I push it to where 2nd should be nothing happens; it is like shifting to neutral.
I am assuming that I am going to pull the transmission but am hoping someone has a magic solution that I can do with the trans in the car.
I also have a carb/tune up question that I will post separately.
Thanks in Advance
Dennis
Thanks in Advance
Dennis
