Hazard switch
artpart
Member
The hazard switch on my '70 tr6 is broken and Moss seems to be the only company that sells one at a cost of $180...ouch! Has anyone used a later switch with success on their car?
Who all have you tried?
TSI?
BP Northwest?
Rimmer Brothers?
Google UK search for Triumph hazard switches?
Is the toggle switch physically broken or just not working?
If it just isn't working, carefully disassemble it as the plastic can be very brittle. The copper contacts inside can be cleaned with a pencil eraser.
You just have to work in an area where flying springs and other small parts are easy to find.
Hazard switches are available on ebay fairly often. You just have to make certain that you get the proper number of spade terminals on the back. Earlier cars had four, while the later ones had six.
Have you heard of Google?
It is a search engine that is a rather useful resource for locating parts.
I just did a Triumph TR6 hazard switch and got a bunch of entries.
Might wanna do the same.
The hazard switch on the '69-'71 has four terminals on it. The switch for the '72 has six terminals on it. Of course, the '73-'76 is a completely different style switch. The earlier switch activates a relay, whereas the later six terminal switch doesn't.
Dan Master's wiring diagrams shows the interal contacts of the early switch, but not the later one. Therefore, without having one in hand to ohm out the switch contacts, I can't say whether or not you could use the later switch. The other question, is whether they are the same pysical size and will fit in the dash.
Thanks, guys.
Ron, I tried vb, moss, and trf. As I said, moss is the only one that had the switch ... for nearly $200. I'll try the others you mentioned, including Google.
Doug and Art,
I've ordered a later switch to see if it will fit in the same hole, though I suspect not without modifying it. My switch is completely broken apart.
I dropped it of with our local british car guru, art ziesk, before I left town. Apparently when the switch breaks, it causes the turn signals not to work since they are all tied in together. Anyway, Art says the switch is beyond repair.
Thanks for the info.
Chris
Chris,
It's very easy to replace that switch with an ordinary DPDT switch from your local auto or electrical supply store. You'll need to leave the old switch in place and hide the new one, as the new one won't match your dash. You'll save yourself a lot of trouble in the future if you do this, as the turn signal power goes through the hazard switch, and this causes most of the problems with sluggish or inoperable turn signals.
The diagram for this is shown on page 122 of my electrical repair manual, but if you don't have a copy, let me know and I'll send you a diagram by e-mail.
Art,
The internals of the later switch are pretty simple: with the hazard switch off, terminals 7 and 8 are connected together inside the switch. In the off position, terminals 1, 2, 3, & 4 are connected together.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]this causes most of the problems with sluggish or inoperable turn signals.
[/QUOTE]
Or smoke and melted plastic as mine did.
When I got my 6 (71)10 years ago the hazard wasn't working. I recieved a new later style 6 pin and after enlarging the hole and much moving of wires I was able to get it to work. I can't belief Moss has the old style I thought they where NSF
All, both swithces use a roll pin to activate on or off and the later style is a bit larger and was used on the Spits's and GT6's. The pins for the wires were small on the early switches and I would not cut them to install a newer switch, use a 3 or 4 inch pigtail, tape them up well and hope you can find the right one at a later date. The later switch works fine but requires a bit of filing on the wood and metal behind the wood. I found the small spring and the plastic hook for the roller brake in the early switch, it was so small that is why they went to the large switch is my guess. Sorry I can't rememeber the wiring for the later switch, but it will work with just the four wires. I was lucky and found a early one and have replaced the bigger one. The larger hole did not look out enough to worry about and the switch is tight.
Wayne
Wiring to use the later switches is pretty easy:
P - pin 1
PR - pin 2
LG/N - pin 7
LG/N - pin 8
It doesn't matter which of the LG/N wires goes to which pin.
SherpaPilot TR6 Hazard Switch Problem Triumph 8
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
tinman58 TR5/TR250 Hazard switch $189.00? Triumph 10
F TR6 76 TR6 Hazard Switch Triumph 1
A Wedge TR7 Hazard Light Switch Triumph 1
R TR5/TR250 TR250 Hazard Switch Triumph 8
Mickey Richaud T-Series Hazard/Rear Window Defogger Switch MG 7
dklawson Spitfire Spitfire - Hazard Switch Removal Triumph 3
walshja me again, Hazard light switch Spridgets 11
Got_All_4 Any one purchased a 4 way hazard switch from VB Triumph 6
D hazard switch wiring ? Spridgets 1
MadRiver T-Series '68 Hazard Switch Question MG 4
M 87 XJ6 Turn Signal/Hazard Flasher Switch Problem Jaguar 16
H Esprit hazard switch needed Lotus 1
kyreb1862 T-Series Hazard Switch MG 2
B T-Series bypass hazard switch MG 17
B T-Series pic of hazard switch MG 2
MrPandy TR6 Hazard switch wiring - '71 TR6 Triumph 7
Mark_Gibson TR6 TR-6 Hazard Switch Dress Up Ideas Triumph 3
G T-Series hazard switch MG 3
D T-Series 1972 MGB Hazard switch. MG 6
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
Got_All_4 Wedge Hazard siginals don't work!! Triumph 4
B MGB 79B hazard line fuse MG 1
T TR2/3/3A Hazard::TR3 bonnet stayrod assembly crack Triumph 1
JFS Wedge TR8 Hazard Flasher Triumph 15
Jim_Newman Hazard warning lights Austin Healey 1
Woodie TR6 tr6 76 hazard flasher...not Triumph 8
L TR2/3/3A Hazard Flashers for TR3A Triumph 4
hondo402000 TR6 hazard flasher unit for 69 70 71 TR6 model Triumph 22
hondo402000 Hazard relay and hazard flasher question Triumph 9
M Leaking oil and fire hazard Triumph 11
RickB Hazard a guess? Sparky Carb Spridgets 12
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
Woodie HAZARD LIGHTS Help please Spridgets 3
C TR6 TR6 Hazard Switches Triumph 2
John_Mc Hazard wiring dilemma Triumph 3
B Hazard Relay Pic Triumph 3
MadRiver Lucas Hazard Switches Triumph 6
Steve1970 TR6 TR6 - Should turn signal work if hazard is gone? Triumph 8
H TR6 Where is the Hazard Flasher located on a '71 TR6? Triumph 8
I TR6 TR6 Brake line, hazard warning light not working. Triumph 3
M Spitfire hazard circuit diagram for 69 Spitfire Triumph 9
ecurie_ecosse Hazard Warning lights. Spridgets 4
RSMTR8 Wedge TR8 Hazard Lights Triumph 2
R6MGS TR6 TR6 Hazard lights Triumph 17
J Spitfire Hazard flasher on 78 Spitfire Triumph 1
R6MGS Hazard lights relay Triumph 4
