Gettin down in the back seat
Reh
I am getting close to interior work with my GT6+, and I really want to get a back seat for it. Now obviously finding a used one is impossible, so is there any other seats that would work?
The only picture i can find is a sketch for a parts book.
I am sure I am wrong but all I ever really remember seeing in the back of the GT6 on the shelf was like a cushion that sat on the bottom of the self but it didn't have anything up the back other then the carpet.
But that is trying to remember from 30+ years ago when I use to sit in the back of my friends GT6+ when for some reason the girlfriend got the front seat.
I don't know where you would find one, but here are a few pics of what you would be looking for.
GT6 Rear Seat
Learned something new today. What ever my friend had was not a seat but maybe something added.
I am not sure what use it has other then to look neat. Your kid would have to be really small to fit on that with no legs and you would have to put in seat belts in most states as well if you want to make it usable.
But it is very neat.
I saw that seat kit in a catalog. Years ogo when Mom had her GT6, I was shoved in the back so my older Sister could drop off one of her freinds after school. I was at the six foot height then. That car, like mine, had just the carpet coating and no seat.
I cannot imagine trying to actually sit in that well.
Being only 15 i hope i don't have a kid anytime soon.
I want to get one for looks, but i bet sometime one of my friends would get put back there. Well that will probably happen even if i don't find a rear seat.
Andrew Mace said:
I have seen a factory-optional back seat installed in a GT6+. I've a feeling your friend would be more comfortable in the "bare" behind-the-front-seat area than he/she would if the factory seat were installed!
Very true. Also The back rest sticks up a little too much for me. And considering how thick the carpet is right there I wouldn't even throw in a cushion.
I might just get some foam from a hardware store and make my own. Cheaper, and might look better.
Holy crap!!!! Found a guy in colorado that has the frames for a back seat for a GT6+. But wait its british so they might be rusted away.
mctriumph Gettin out the Mini Cooper Other British Cars 0
tinman58 TR5/TR250 250 gettin there Triumph 4
DrEntropy MGB This is gettin' tiresome MG 22
PatGalvin It's gettin' done, slowly... Triumph 72
martyc Gettin' Ready For Spring! MG 1
Banjo I'm gettin a motor. I'm gettin a motor! Jaguar 5
frankenstang57 Looky what I'm gettin'! Triumph 16
mctriumph TR2/3/3A The oddest breakdown Triumph 11
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
R TR2/3/3A Engine revs up and down Triumph 7
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 22
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
M MGC New book: MGCs Down Under MG 0
shadowfever Shake down run Spridgets 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
T TR2/3/3A rough running after 20 min shutdown Triumph 9
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
Busted knuckles TR2/3/3A Engine tear down, Triumph 13
Rut Cut down windshield Spridgets 22
S TR2/3/3A trim to hold down the furflex Triumph 3
Sopwith_Camel up or down? Jaguar 12
Editor_Reid 2011 Aston Martin V8 Vantage N420 Goes Full Lockdown Other British Cars 54
D TR2/3/3A stator tube will not go down Triumph 0
K Austin-Healey Fold-Down Windscreens Austin Healey 27
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
roscoe Leakdown test [long read] Austin Healey 11
DrEntropy Diesela won't go down... Other Cars 5
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
DrEntropy MGB Shakedown run MG 6
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
wangdango BJ8 inner battery hold down? Austin Healey 4
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G Supplier rant from down under Austin Healey 12
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
M Hauling a Spridget - Proper tie down technique? Spridgets 15
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
77MidgetMkIV Great Shakedown! Spridgets 4
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
RickPA Overdrive throttle switch caused meltdown Austin Healey 2
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
GTP1960 Drive down memory road. Other Cars 14
AngliaGT MGB When the MGB is Down..... MG 1
KVH General Tech Engine Teardown on the Way Triumph 43
KVH General Tech Leak Down Test Triumph 17
aero3113 100 hard top with windshield folded down. Austin Healey 4
