    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Front Springs too stiff?
Sportsdoc
Just got the car back down on all fours, yet the front looks way too high. I replaced the front springs and remember the length looked correct. At rest the shock dampers are touching the rebound bumpers.
Have I gotten the wrong springs?
Did you leave the suspension with rubber bushings loose until it was sitting on the ground? If you tightened them while the suspension was hanging that may be part of your problem.
forgot to say... the solution is to loosen them, bounce the car, then re-tighten.
Is the motor and trans in the car??
And the front sheet metal and radiator in?
Stock spring for steel bumper is 9.5 high .500" wire and 7 active coils.
Still too high.....? post the length of the spring , the wire size and # of coils.
If you ordered Springs from VB or MOSS chances are you found out like I did that they are selling springs marked incorrectly. I ended up reordering springs marked for a Bugeye in their book in order to the correct springs. Placed side by side, the and I can't remember if it was from VB or Moss, springs stood physically 3/4 of an inch taller but are much stiffer. Instead on a 1" or so tire / fender gap it was more like 2-3". It took 3 tries b/4 I ended up with thecorrect springs. I think I've got pics and I'll send if you want.
The pics would be helpful. I put a jack under the wishbone to level it before I tightened the bushings. I have at least a 4 inch gap between the top of the fender and the top of the tire. I do have the engine in; don't have the radiator or generator installed.
I have spoken with the vendor and he is checking into it. Won't be the first time I got the wrong stuff. Wrong brake calipers, wrong brake cylinders, hub with bent studs, etc....
""""""I put a jack under the wishbone to level it before I tightened the bushings. """""""
You want to get the car on the ground with the bolts/nuts on the a-arms loose and jump up and down on the car then tighten the bolts /nuts.
"""""""" don't have the radiator or generator installed."""""
So your lacking 90-100 pounds or so + -. With the car on the ground stand on the front of the car and see what happens. If the ride height is not resolved then remove the springs and measure them...see what you have.
IF you have a steel bumper (POST B.E.) (you didnt say just what you have) the spring dims are above in my prev post.
Just got one of the springs out.
9 3/4 inch length, 8 coils, .5 wire, green dot on springs with CHA-129 part number.
Sounds like a later model with rubber bumper car at the height/coils you say....if you didnt measure the wire to three places ( .XXX") , remember that wire size is the BIG variable on spring rates.
You might contact the vendor......
"""""""I have spoken with the vendor and he is checking into it"""""""
Ask him who is HIS SOURCE and call them.
I'm sending them back to my previous vendor and ordered the proper set from Peter C.
I hope to get the front end properly finished this weekend.
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
K TR2/3/3A Front coil springs? Triumph 2
Z Front Springs Removal Austin Healey 3
Jayplum TR2/3/3A Front suspension / springs Triumph 5
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A TR4 front coil springs Triumph 0
T TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question. Triumph 1
bugedd Front suspension springs Spridgets 4
B Front springs for phase 11 BJ8 Austin Healey 1
PAUL161 T-Series TF Front Coil Springs MG 1
oxford front springs Austin Healey 5
S TR front springs Triumph 3
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
T stock bugeye front springs Spridgets 4
S Spitfire Question front shocks and springs for 73 spitfire Triumph 5
bugedd Bugeye front lowering springs Spridgets 0
AN5Sprite Front Springs Spridgets 0
George Zeck Front Springs ...... Spridgets 31
bugedd front springs Spridgets 5
PatGalvin Front Coil Springs Triumph 9
DWeeB Front Springs Question? Spridgets 6
boxfullofyertoys Front and Rear Springs...Repair? Replace? Spridgets 12
T Front springs - just call Richard Triumph 18
drooartz Which front springs? Spridgets 4
E BE Front Springs Spridgets 9
T MGA Difference between MGA front springs? MG 0
M TR2/3/3A TR3 Front Springs Triumph 9
Baz Front springs and bushings.... Spridgets 44
1 Which way to compress front springs? MG 30
vping MGB-GT Length of front springs. MG 9
Jerseygirl Spitfire A lesson in Spitfire front springs... Triumph 4
fad64b TR2/3/3A TR3 Front Springs Triumph 6
JPSmit Front Springs Spridgets 4
RickB What to use for spacers - lowering front springs. Spridgets 37
B Reinstalling front springs. Spridgets 11
Stewart Anyone need a new pair of front springs 75-80 MG 2
Editor_Reid Healey 100 Front Springs Austin Healey 7
jlaird Question of the day- front springs Spridgets 6
HAN8L1965 Removing Front Springs 65 Sprite Spridgets 1
SCguy TR6 TR6 front bushings and springs questions Triumph 5
PAUL161 Front coil springs MG 1
mondialo64 TR4/4A TR4 vs 4A front springs Triumph 4
G Front Coil Springs Removal Spridgets 9
L MG Midget Front Springs MG 5
Cain TR6 Front TR6 Springs Triumph 12
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
