Hi
I have just bought a 1958 frogeye sprite and am having trouble getting the car into 1st or reverse gear when the engine is running (will go in if you switch the engine off)
All other gears are fine, and am presuming that I have a clutch problem as there seams to be very little travel on the peddle – is there away of adjusting this? As the clutch is not slipping?
Help appreciated
Help appreciated
