MGB external alternator regulator
emmett1010
installed a new wiring harness for 1968 mgb. This harness is wired for a 5 wire alternator with an external regulator.
I'm wanting to install the later 3 wire alternator with internal regulator. I will buy the adaptor to convert the 5 wire setup to the 3 wire setup, no problem, but what should i do withe the external regulator.
leave it plugged in
leave it unplugged
change some/any of the wiring?
leave it plugged in
leave it unplugged
If you're getting the three wire adaptor, get the faux regulator and follow the included instructions on wiring connections. It is internally set up to be used with an alternator that is internally regulated...
T external sealant for oil leaks Spridgets 6
Zimmycobra For Sale Misc. External Engine Parts - 1966 TR4A Triumph Classifieds 1
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
T External ballast resistors - do they go bad? Triumph 8
T TR4/4A TR4A wiring - gear reduction & external solenoid? Triumph 6
T External Mirrors - advice requested Austin Healey 10
T External Trim Restoration Restoration & Tools 1
Hap Waldrop Ray's external oil system Spridgets 3
Bob McElwee Bugeye Hardtop External Latches Spridgets 2
TR674 External oil line Triumph 23
eschneider external rocker oil feed line Triumph 13
A Internal hinge converted to external? British Motor Corp 4
MikeAH100M Alternator Conversion Issue Austin Healey 14
P Generator-to-Alternator Conversion Austin Healey 7
T TR6 Alternator wiring Triumph 6
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
