cost of a new top
I am considering a new Robins Everflex or Sun-fast top for may BJ8. The shop that did the painting (famous restorer of classics and hot rods, they know their stuff)will do it complete for $950. High? Low? or just right?
Thanks
TH
The cost of the top is probably a bit more than half of their bid. Based on the amount of labor I put in doing my own, I would say that is probably a fair price for the top and installation. It is one of those jobs that seems like it will never be possible, and then little by little you get it the way you want it. If I had a full head of hair I would have pulled most of it out doing this, but I'm happy with the results. It was the first, and hopefully the last, one I'll do.
Thanks
TH
Comparison shopping at the convertible top installer shops in my area, were quoting prices around $1,200. Robins Everflex, installed.
Mine ended up costing around $2,000 when all was said and done.
That included sending the metal frame out to be blasted then power coated the correct color grey.
They also fabricated a stainless steel wire with a spring for tension, into the area over the windows. It helps keep that area from stretching/rising over the years. (Modern convertible top have them).
After getting back from them, I put in a lot of hours in adjusting the roll up windows to meet the top perfectly. You can adjust the windows to the top, but not the top to the windows. The window to top adjustment goes hand in hand with the rubber seal too. The seal gets attached to the aluminum holding rail. That can be moved and adjusted too.
When having a shop install the top, questions need to be asked about how much tweaking are they going to do, to the finished product.
Will the frame need to be tweaked to get the new top to fit better? (Mine did). Will they be adjusting the windows or seals too? Will it be water tight everywhere? Will there be wind noise?
I monitored the top install and I'm glad I paid a professional to do it.
The better the installer, the better the end product.
You do get what you pay for.
I asked all the shops I talked to about their experience with Healeys. A lot of them said it did not matter. They learn about the Healey from taking the current top off. Then it's a matter of tweaking the frame and top together to get a proper fit. I looked at their work and how professional they sounded. I did not go with the cheapest bidder. And I told the shop that I ended up using that. I told them I chose them for the quality that they promised me. I made that clear up front.
tahoe healey, sounds like the price is reasonable, could you have them give you the price for labor only, i was able to buy a new sun fast in the box top for my bj7 for $100.00, list price at that time was over $600.00, and a new tonneau cover for $50.00, might take some effort to find this kind of deal but i think its worth the time. :savewave:
:yesnod: Beautiful job indeed. I'd never put the top down if mine looked as good as yours.
AUSMHLY,does your '64 BJ8 use a clip in rear window like my '63 BJ7 or zip in like my '67 BJ8 phase 2? cheers Genos2.
Mine has the zip window.
I have a phase 2 BJ8
I unzip the window and hang/place it in the area where the top stores before I fold the top down . I've been told that helps keep the window from getting creases and does not put stress on the zipper when putting the top up or down.
I've been told to keep the top up when not in use. Even when the car is under a car cover in the garage. (Hey I'm not the only one who has a cover on when in the garage, am I....?) Anyway, I was told to put the top down when going for a ride, and to put it back up when done.
So I do, and my top still fits and looks like new.
I keep it clean and protect it with Areospace 303 on the Everflex and the window. It keeps the window from turning yellow, drying out and cracking.
I drive the car with the top up more than down. All those weeks (the learning curve) spent getting the windows and seals to fit perfectly, really pays off when driving. I hardly have any wind noise and no water leaks down the windows. Really. Now that small drip under the dash, if I could just figure where that comes from. (I've posted on that topic before, so let's not go there...here).
Cheers,
Roger
Roger, is your top a Robins? The rear window is a lot larger than my current one. Is it Everflex or vinyl? Looks good.
I thought you were going back to the original steering wheel.
TH
TH
Robins top.
Everflex is vinyl.
Sunfast is cloth.
As far as why your window (if a zip out) is smaller than the Robbins top I have, I believe mine is the correct size. I didn't modify the window size.
Robins uses Everflex which has the correct pattern cut and the material has the correct looking grain. My Blue colored top has the grey interior "headliner" even though it's not really a separate "Headliner" and has the two correct sized grey straps.
I did replace the Mota-Lita steering wheel back to the original banjo style wheel. (Those photos are older, taken when the top was installed. I always take photos along the way durning my restoration).
Good catch Eagle Eyes! Oh, that's right, you are an Optometrist.
Cheers.
Thanks Roger. Did the straps come with the top? Moss sells something they call "crush grain vinyl". I cannot wait to see your car dirty someday (yeah, like that will happen).
Roger
Just spent many many many hours trying to get my windscreen on, wrong seal etc etc (dont ask), I found that I could see daylight just off centre between the shroud top and windscreen to shroud seal. As I tightened up the centre well nut it would lift the screen up and there was a slight gap at one point if you put your nose level with the inside where the mirror goes. To check you would have to remove your dash padded top. The water can run to the sides / footwells as the shroud has an indent / channel in it which the screen sits on.
If I had not been sitting on the tunnel with my eye level with the dash top I might never have seen the wisper of daylight!!! I had to adjust the bracket and get a new well nut. So the screen went off / on anothe time!!! Worth a look???
cheers Andy
Hey Rich,
The two straps (webbing set) did not come with the Robins top. If memory serves me, I purchased them from Moss.
Are you going with the crush grain vinyl?
andybj8 said:
Roger
cheers Andy
Hi Andy,
Thank you for sharing your story and thinking of my situation. I too thought of water coming in from under the windscreen seal. So I removed my dash top, and ran water down the windscreen and watched, hoping that was where the leak was coming in. I did not see water access there. I posted about this here on the forum. Someday I may revisit the leak area. Thank you for suggesting that area.
Cheers,
Roger
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
steveg Cost of V8 conversion Austin Healey 34
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
HealeyRick Why 100Ms Cost So Much Austin Healey 14
Bob Claffie Wedge TR parts cost Triumph 3
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
TR4nut TR6 Ballpark cost - TR6 trailing arms? Triumph 4
CessnaTPA Paint Job Cost Austin Healey 32
toysrrus TR6 Weber DCO45 cost? Triumph 6
RAC68 Dash Lighting [cost and access of incandescent Bulbs] Austin Healey 37
S Low entry cost into AH ownership? Austin Healey 18
DornTRoriginal General Tech Starter Mounting "Cage Nut" Delima and Poloshing Cost Outrage Triumph 27
Boggsy64 General Tech Paint cost MG 23
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
regularman This is a good deal but would cost me my marriage Spridgets 5
T Before you complain about TR parts cost Triumph 21
J Cost for front suspension refurb right/wrong? Spridgets 8
BugeyeNJ58 Cost to ship 1275 Cylinder Head? Spridgets 9
L Cost of a rolling MG-B chassis? MG 14
RickAnderson Cost of Chrome Plating Restoration & Tools 5
L What does it cost to ship a Datsun 5-Speed? Spridgets 7
BugeyeNJ58 Cost to recore radiator? Can a radiator be identif Spridgets 7
P Engine Machining Cost Triumph 20
T Pete Delaney/Smitty's 5 Speed - Cost & Description Austin Healey 0
T cost of shipping cars across the Atlantic? Spridgets 1
BOBBYR The cost of chrome. Austin Healey 27
mountainman TR2/3/3A Cost of New TR3 Triumph 19
M How much would it cost/Did I make a good purchase? Spridgets 29
M 3 synch OD Gearbox rebuild cost MG 1
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Austin Healey 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Spridgets 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Triumph 0
PAUL161 MGB 72 MGB cost new? MG 6
abarth69 What's the average cost to rebuild 1275cc Spridgets 22
JPSmit grille cost question Spridgets 21
W Comparing Wiring Harness Cost Spridgets 8
F So what does a restoration really cost these days? Triumph 115
TR6oldtimer TR6 I'll never complain about TR6 parts cost again! Triumph 14
2wrench TR6 Cost to rebuild TR6 overdrive tranny. Triumph 12
G Next time you think parts 4 the LBC cost too much Other Cars 4
Editor_Reid AH 100 Tune-Up Cost Austin Healey 5
jjbunn Floor Pan Replacement Cost Triumph 10
Tinkerman TR2/3/3A Cost for Chroming TR3 bumper Triumph 16
racingenglishcars Low cost bugeye on ebay Spridgets 1
B How much will this cost ??!!! Triumph 11
beaulieu cost of new windshield for for Sunbeam Tiger ? Sunbeam (Rootes) 1
timbn2 Restoration work ... cost per hour? [ish] Austin Healey 5
B Painting cost Triumph 17
D What does a DAILY driver big healey cost today? Austin Healey 30
B Cost to Register 67 BJ8 in Arizona? Austin Healey 3
