A fan belt breakage destroyed my horn and turn signal wires just outside the steering box. I have a replacement harness.
I can find numerous posts and articles on how to attach the wiring harness to the control head.
I assume you feed the wires down the steering shaft and out through the steering box.
Do you use a stiff wire or something similar to pull them down?
Do you have to remove the bullet connectors to get the wires through the olive and nut.
Any gotchas other than exploding springs and screws so small they should be in watches.
I do have corn head grease for the steering box - thank you John Deere.
Thanks and keep on drivin!
