Alan_Myers
Hi all,
Following up on discussion that got started under another thread...
I'm trying to estimate compression ratio, but have a few "unknowns" making it pretty difficult.
Here's the situation... My TR4's head was milled .125" by the previous owner. In addition, I'll be installing 87mm liners and piston. I might need to rein in compression ratio to help the car run decently on currently available gas.
The displacement of a stock engine is 2138cc (534.5cc per cylinder), the bore is 86mm, stroke is 92mm and it's rated at 9:1 compression ratio originally, with stock head gasket.
Both 86mm and 87mm pistons are flat top (ISTR, some domed and dished pistons were tried in the 4-cylinder TRs in years past, but none seemed to improve performance). So, that's a non-issue. Also, I believe stroke will remain the same.
Here are the problems.... /ubbthreads/images/graemlins/confused.gif
- Don't know combustion chamber volume (i.e., compressed volume at TDC), with either 86mm or 87mm bore.
- Don't know thickness of a standard head gasket (compressed)
- Don't know thickness of optional head gaskets (compressed)
- Don't know deck-to-piston clearance.
Can anyone fill in some of these blanks?
What do you consider a "safe" compression ratio with today's premium, unleaded fuel?
The final point of this all is to make a decision about which head gasket to install:
There is the stock gasket, a shim steel gasket and various thickness of copper gaskets: 1.2mm, 1.6mm and 2.0mm.
Thanks in advance!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
Thanks in advance!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
