    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Changed Plugs, Sooty
ekamm
I changed my plugs in my TR3a yesterday first time since getting car in July.They were all 4 pretty sooty, a sign of carbs being too rich? Is that necessarily true? Also the plugs remove were champion L92yc gap .035 and I replaced with L87YC gap .025 as recommended. Haven't driven it yet. Hopefully I can drive today. If I decide to dive into carb adjustment ( I'm scared to death of it) Is there a staight forward explanation of how to get them tunned correctly. Su's for Dummies or something like that.
Sooty plugs can also be caused by older fuel. Locally here in WI, anything older than 4 weeks doesn't burn completely and the plugs look sooty. Try fresh fuel first. Cheap and easy.
Peter C
If it were me, Eric, I'd be wanting to do a complete tune up. Valve clearance, ignition timing (points, plugs, condensor, rotor and dizzy cap). Then it would be time to check and possibly adjust or recondition the carbs.
Change the oil and filter, especially if the engine has been runnung rich.
The SU's are pretty easy to adjust and not bad to recondition. Worn throtle shafts might require skill or a professional to correct, but the rest is more or less "cook book".
https://www.jcna.com/library/tech/tech0006.htm
https://www.zparts.com/zptech/articles/mal_land/ml_sucarb2/images4/SUcarb_111601d.htm
Wow an encyclopedia of info, not looking that easy. I have new; points,condenser timing set. I need to set valve clearances. Oil change has less than 100 miles on it. I did all of that to get the car running, in addition to replacing most of the fuel supply up to the carbs.
This VTR SITE might help you tune those carbs.
I had no experience tuning my Strombergs so I bought a book similar to this one on EBAY and ended up completely taking the carbs apart and rebuilding them. It was not all that hard and like I said, I had no prior experience and I am no mechanic. My carbs work great now.
Don't be intimidated by them. I have not done SU's but I rebuilt my Strombergs mainly using the one page instructions that came with the kit. Pretty simple. And they work. :smile:
eric, I would bet that your plugs were sooty due to the wide (.035) plug gap. Unless you are sure you are running a hotter than stock coil your plugs won't sure fire and will occasionally miss trying to make that gap and consequently build up carbon...You might try sticking with the .025 gap, I think you'll be happier.
Achtung
SU's are dead simple once you grasp what's happening in there. About as complex as a bathroom faucet. :wink:
Mixture is controlled by raising and lowering the jet orifice via a large hex head device on the bottom of the carbs. One flat at a time on each (they're right-hand threaded) to the "tight" direction will lean it out... using plug "color" to check the adjustment after a bit of a run each time.
I'd have a look at the new plugs before ya start tweakin' 'em. The wider gapped ones wouldn't give good info. You should be looking for a Cadbury/Sudbury chocolate color. :wink:
The PO(my dad) had the old wider gap hotter plug in. I replaced with recommended plugs with.025 gap Now am waiting for new float delivery. So when I get it and can run her again I'll take my turn at watching the new plugs and carb adjust.
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Lin Times have changed - thank goodness! Austin Healey 13
NutmegCT So many cars! So much has changed! Other Cars 10
S TR2/3/3A when the seats changed Triumph 5
DrEntropy Default font size changed? FORUM Navigation Questions 1
H Has anyone changed their electrical distribution? Austin Healey 7
Cookie Has anyone changed wheel cylinders? Spridgets 20
bighealeysource How can I tell if the polarity has been changed on Austin Healey 20
jcatnite Something changed Spridgets 6
G Torquing rocker pedestal changed clearances Triumph 1
TR4 Should Tranny Oil be changed? Triumph 8
SCguy Wedge TR8 Fluids changed/detailed pictures Triumph 7
Paul Slice Changed my tune....... Triumph 2
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
trglory TR2/3/3A TR3a spark plugs Triumph 1
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
L T-Series Spark plugs again ? MG 2
B TR6 Gas on spark plugs Triumph 7
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
kodpkd Spark Plugs Austin Healey 3
L TR4/4A spark plugs Triumph 9
A MGB Welsh plugs MG 9
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
M For Sale NOS Champon NA-10 Spark Plugs Jaguar Classifieds 2
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
B TR4/4A Spark plugs Triumph 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
S Spark Plugs Spridgets 2
AUSMHLY BJ8 NGK Spark Plugs Austin Healey 13
AUSMHLY When to replace spark plugs Austin Healey 1
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
longbridgehealey NGK plugs Austin Healey 23
S TR2/3/3A little rubber plugs Triumph 3
S TR2/3/3A Overdrive drain plugs leaks Triumph 3
A Oil Galley Plugs Spridgets 0
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
tahoe healey Spark Plugs Austin Healey 20
I Weeping Core Plugs Austin Healey 6
G spark plugs Austin Healey 10
R General Tech Aluminum oil gallery plugs Triumph 3
S TR4/4A 1/2" blanking plugs Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
vickxxx T-Series 1952 MGTD spark plugs. MG 4
Tim Tucker TR4/4A Reading my TR4's plugs [L-87YC] Triumph 8
KVH TR4/4A Stumped Again on Carbs Fouling Plugs Triumph 16
Marvin Gruber Auto Zone $15 freeze plugs Austin Healey 3
Got_All_4 General Tech How do i get these out? Tranny cover plugs Triumph 6
KVH General Tech Carbs flooding and Plugs Fouling Triumph 9
M Can you identify these plugs? Spridgets 18
