Can we talk carbs
jlaird
I now have no leakage, none at all. Either setting or running since last evening when I found the problem and fixed it.
I can make it idle down to 13 to 1500 with out problems.
However, I can not get it below that.
Timeing is at 5 or 6 degrees, old eyes again, hard to see that mark even painted and such. Far as I know it is a stock cam, had the marks for one in any case.
Throtle adjusting screws all the way out, carbs seperated.
Starts well, when I lift a carb piston a bit it wants to die, yea I know too lean but if I take it out anymore it runs faster and remember I can not get the idle down any further with the adjustments the throtle disks are closed, pointing the correct direction, etc.
Have checked many times for air leaks. Get about a 2 or 3 hundred RPM increase with carb fluid on the throtle shafts. Does not seem excessive, that's preaty volitle stuff.
I beleive the valves are correctly set as well, was very careful there.
What's left guys, what am I overlooking?
The heck with the timeing mark. Just adjust it for best and smooth operation? Seems to be better if I move timeing up to about 10 or 12 degrees BTDC. Am I correct with the 5 or 6 degrees?
According to my books, you are right with the 5* - 6* setting. Too lean a condition will make it rev faster. The choke isn't "on" slightly? What happens when you make it richer? It should slow down a bit! I know it sounds elementary, you set the throttle screws, but how about fast idle and choke screw settings?
Choke screw settings are about 10 at the present.
Fast idle screws are almost closed. Strange isn't it.
Boy is she happy over 2000 RPM, really smooths out and axcelleration strong and smooth.
At idle, as low as I can get it, maybe 1500 or a bit less, she is lumpy, and does not want to axcelerate.
When you raise a piston she wants to die. Can not seem to get it to stop that.
Aye Mike, and the place it the throttle bearings. Would you beleive they are new, so is the shaft and the butterflys. Seemingly it takes very little air to really screw up the idle, had no idea. Tis a wonder so many of the old 948s ran at all even though folks were always complaining about there high idle. always got about 800 myself although I had no idea.
Think someone was asleep at the switch.
Will pack the ends of the throttle rods in heavy grease tomorrow and see if that improves the situation. I think it well but will advise in any case as it sounds like such a great trick for testing air leaks after you have located what you think is one.
drooartz MGB Talk to me about bottom end bearings MG 34
R TR2/3/3A Let's talk seats Triumph 27
Patrick67BJ8 Let’s talk motor oils Austin Healey 64
exfed12825 MGB Lets Talk Windshields MG 5
RickB Tom Magliozzi, MG owner and co-host of Car Talk - RIP Spridgets 3
J General TR Let's Talk Timing a TR2/3/4 for Performance. Triumph 6
T let's talk paint jobs Austin Healey 2
H If Austin Healeys could talk... Austin Healey 10
Willie_P TR 3/4/6 -try to talk me out of this: [suspension] Triumph 28
tri_carb_healey outrigger talk Austin Healey 4
T Let's talk spring pans for Disc brakes Spridgets 4
T Let's talk tropical fans... Triumph 1
B Someone talk me off the ledge Triumph 15
T So let's talk paint colors... Triumph 39
T Let's talk acid Triumph 11
T So let's talk about powder coating Spridgets 17
T OT - let's talk about car control Triumph 20
QuickSilver Let's Talk Tail Lights MG 7
T I couldn't talk him into something British.... Other Cars 8
T Let's talk about stainless steel brake lines... Triumph 4
R TR6 Wiggly Winders or lets talk window regulators TR6 Triumph 7
healeynut Talk about your rare cars Other British Cars 0
lbc_newbie Talk about your Barn Finds... MGB on WA craigslist Spridgets 2
JPSmit Can someone please talk me through Spridgets 10
S Talk about rare....... Other Cars 25
RickB OT: talk about making a Spridget Hybrid? Spridgets 0
T TR6 Let's talk TR6 door gaps! Triumph 20
2wrench TR6 TR6 Builders STOP TILL WE TALK COOLING Triumph 19
7 lets talk about radiators Triumph 13
J So let's talk brake lines Triumph 16
Atrus Let's talk towing a spridget! Spridgets 10
6 Lets talk about this!!! Spridgets 8
jlaird Sprite talk Spridgets 11
2wrench TR6 '74 TR6. Let's talk about disconnecting smog stuf Triumph 29
2wrench Let's talk about the dreaded thrust washer wear. Triumph 8
AngliaGT Someone Talk Me Out of This Triumph 23
T Someone talk me out of this.... Triumph 37
Nunyas Talk about timing! Not iggy timing... sheesh MG 7
RickB Talk her into keep it &join here! -was:64 Sprite.. Spridgets 4
B So that's the sound you all talk about!! Austin Healey 9
Atrus Let's talk oil leaks ;-] Spridgets 16
jlaird Had a long talk Spridgets 17
G Someone talk some sense into me... Triumph 33
T ok, lets talk about headers Triumph 9
DrEntropy Talk about TIMING!!! Racing 3
jlaird Can we talk about tire brands here? Spridgets 2
Alan_Myers GT6 Please talk to me about Rotoflex, GT6 in general Triumph 10
J Talk me out of it- '79 B for play and track [noob] MG 27
jlaird Question-lets talk steering racks Spridgets 1
HAN8L1965 Lets talk rear springs 1965 Spridgets 4
