Any one purchased a 4 way hazard switch from VB
Got_All_4
I posted this question over the weekend but it did not show up. I suppose from the server switch over. Any way has any one purchased a 4 way hazard switch for a TR250 or 6 from Victoria British. If so any problems with fit and compatibility. Mine blow up and lost parts. It was on it's last leg anyway. Don't want to cut out my dash and I need it to work. The price is much cheeper then Moss's.
It must be the over sized 1 that has the 6 connectors. You will have to figure the wiring ,though I think I've seen it posted somewhere.Occasionally the 4 prong ones pop up on the "Bay" .
The dash will need some carving along with the metal back piece
I bought one of these from VB and it did not come with instructions. I did call them and they faxed the instructions to me. Try calling. If they can't help, I can look for my copy.
I guess they thought they had smarter customers. After all it is only 6 wires, how tough can it be??
Jerry
When you only had 4 post originally and your electronically illiterate .
I'll bet that it's for a different brand of car and they are re-labeling it for use in a Triumph. I thought I remembered some discussion here of the nightmares of cutting up the dash to fit. Moss is $200 for theirs and if it fits like OEM I'll just have to start saving my pennies and my dimes and in the mean time if one shows up on the Bay I'll have a war chest to bid. Thanks
I did not install it into the TR3A. I put it into a BJ8. I mounted it on the steering column support. You can't see it but it is there if you need it.
Jerry
TR3a
BJ8
LarryK GT6 Fresh purchased GT6 Triumph 11
S TR2/3/3A purchased a box of tr3 parts this weekend, Triumph 1
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
hondo402000 TR6 TR6 knobs purchased on ebay Triumph 9
J Just purchased an 84 280i from the UK TVR 15
robdmau Just purchased a 1965 Austin Healey Sprite... Spridgets 26
robdmau Just purchased a 1965 Austin Heley Sprite... Austin Healey 7
E TR4/4A New Comer with a recently purchased TR4a Triumph 16
obsesstoration Just purchased 63 former SCCA racer in NJ MG 24
T TR6 Purchased a second TR6 Triumph 29
S TR6 Just purchased my first TR6 Triumph 19
T TR6 TR6 Tires - Purchased Coker Redlines, Very Happy Triumph 1
E MGB Just purchased 79 MGB MG 8
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
SherpaPilot TR6 Hazard Switch Problem Triumph 8
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
Got_All_4 Wedge Hazard siginals don't work!! Triumph 4
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
tinman58 TR5/TR250 Hazard switch $189.00? Triumph 10
B MGB 79B hazard line fuse MG 1
T TR2/3/3A Hazard::TR3 bonnet stayrod assembly crack Triumph 1
JFS Wedge TR8 Hazard Flasher Triumph 15
F TR6 76 TR6 Hazard Switch Triumph 1
A Wedge TR7 Hazard Light Switch Triumph 1
R TR5/TR250 TR250 Hazard Switch Triumph 8
Jim_Newman Hazard warning lights Austin Healey 1
Woodie TR6 tr6 76 hazard flasher...not Triumph 8
L TR2/3/3A Hazard Flashers for TR3A Triumph 4
Mickey Richaud T-Series Hazard/Rear Window Defogger Switch MG 7
hondo402000 TR6 hazard flasher unit for 69 70 71 TR6 model Triumph 22
hondo402000 Hazard relay and hazard flasher question Triumph 9
M Leaking oil and fire hazard Triumph 11
RickB Hazard a guess? Sparky Carb Spridgets 12
T Voltage stabilizer, turn signal flasher, hazard Spridgets 2
QuickSilver MGB 77 MGB - Turn Signal, Brake Lamp and Hazard Issues MG 22
Woodie HAZARD LIGHTS Help please Spridgets 3
C TR6 TR6 Hazard Switches Triumph 2
dklawson Spitfire Spitfire - Hazard Switch Removal Triumph 3
John_Mc Hazard wiring dilemma Triumph 3
walshja me again, Hazard light switch Spridgets 11
B Hazard Relay Pic Triumph 3
D hazard switch wiring ? Spridgets 1
MadRiver Lucas Hazard Switches Triumph 6
Steve1970 TR6 TR6 - Should turn signal work if hazard is gone? Triumph 8
MadRiver T-Series '68 Hazard Switch Question MG 4
A Hazard switch Triumph 11
H TR6 Where is the Hazard Flasher located on a '71 TR6? Triumph 8
I TR6 TR6 Brake line, hazard warning light not working. Triumph 3
M Spitfire hazard circuit diagram for 69 Spitfire Triumph 9
