drambuie
Hello everyone! I would like to ask about taking the slack out of the steering box using shims as recommended in the bentley manual. My steering movement is not really all that bad but i would not mind a little more positive feel and a faster response in my steering wheel. I would assume by taking away shim thickness it would put more preload on the inner race which in turn would take out some of the end play in the box but not too tight as to bind movement and then turning in the adjusting screw a small amount as to remove steering wheel slop.I would like to ask if anyone has reshimmed a steering box before? What where the results? Any problems to watch out for? Would it be better just to turn the adjusting screw in a bit and not reshim the end play at all? Thanks for any advice pertaining to this subject. Michael.
