T-Series 53 TD - round rear lights
NutmegCT
How do I remove the rear light cover, to change the bulb?
The Ops Manual only shows the pre-1953 "rectangle" light fixture, held in by two visible screws.
The later round light is similar to this:
Gol dern it - how do I open that lamp cover?
Thanks.
Tom M.
Carefully pry off the chrome rim with a small screwdiver, then pry the lens out and there ya go!
Thanks Mickey. So the chrome ring can be pried off, releasing the red plastic cover? Nothing needed but small screwdriver?
Paranoid Tom
Yep, that's it. Clever, that.
Use a plastic headed screwdriver. You'll find out why after the other one slips and scratches the paint. The lens is glass.
Oddly as it may seem, a paint can opener works also on opening up the rubber to grab the lip on the chrome ring. If the rubber is old, use caution as it could tear. PJ
You're learning...remember, don't overtighten LBC lenses - they crack. The '53 TDs have different and better instruments, a 3-bow top replacing the 2-bow, POS Lucas wiper motor moved to the center of the windscreen (possibly due to a navigator being knocked unconscious during a rally), 3/4" reach spark plugs, smaller valve clearances, different tail lights, a water temperature gauge! Remember also to check your oil consumption. You should have at least 55-60 lbs of oil pressure under way.
Thanks. Abingdon Spares is an hour away, and they're great guys. After replacing the gasket, engine shows no gasket leaks. Oil pressure 55-60, tho' I only ran it for about ten minutes.
Still no luck on the tach, even after replacing the cable from the generator gearbox to the tach. Must be an internal tach problem, as the needle is free to move.
Tom M.
Tom, Might sound crazy but, does the inter cable turn when the engine is running? There is a specific reason for asking. PJ
Paul - thanks. The internal cable turns. I feel it turning inside the sheath, and I see the cable itself turn inside the sheath when it's not plugged in to the tach.
TM
Well I guess the tach needs attention then. Abingdon should be able to give you a good tip on where to get it fixed, possibly locally. PJ
I believe Nisonger Corp. in New Rochelle is still in business. They repair instruments. When I restored my TD, they gave me gratis a couple of thin rubber gaskets that go around the tach and speedo.
Thanks gents. Abingdon did recommend Nisonger. If you haven't been to Abingdon in Deep River, Connecticut, it's worth a trip. On Friday I saw 3 TDs, 1 TF, 1 PB, 1 TC, and (I think) a TA.
I don't know how to remove the tach, but I'll figure it out eventually.
T.
A TR2/3/3A Those round fuel line clips Triumph 2
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
J TR4/4A Hub out of round? Triumph 2
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
Zitch TR4/4A Who said the TR4 round shift knobs were NLA Triumph 4
J Half round tube or D tube source ?? Restoration & Tools 2
H 1925 Rolls Phantom I "round door Rolls" in Petersen collection: what did it sell for? Other British Cars 5
K TR2/3/3A The round electrical connectors on the OD Gearbox Top Cover? Triumph 1
alanjohnturner TR4/4A pesky right-ange drives , square pegs, round holes Triumph 2
drooartz Which holes in the dash are not fully round Spridgets 11
D Texas All British Car Days - Sunday Sept 29th - Round Rock, TX [just north of austin] Spridgets 5
Tr3aguy Finally getting round to it....help! Triumph 2
T pistons wrong way round Austin Healey 22
B Round the clock Austin Healey 2
J Disc rims all bent and out of round Triumph 11
Cottontop Texas Healey Round Up 31 Austin Healey 2
Cottontop 2011 Texas Healey Round Up 31 Austin Healey 0
lreyburn TEXAS HEALEY ROUND UP 31 Austin Healey 0
T Who in Seattle is buying the first round of drinks Triumph 13
NickMorgan Round Britain Reliability Run Triumph 23
Morris All British Car Day in Round Rock, Texas Spridgets 2
G .002 out-of-round crank build going strong Spridgets 14
abarth69 Vroom Vroom round and round Other Cars 15
T TR4/4A TR4a engine mounts - round vs rectangular & vendor Triumph 13
G TABC Round Rock, TX and Oil Question Triumph 2
Trevor Jessie Round the world Midget driver in Texas Spridgets 15
NickMorgan Round Britain Reliability Trial Triumph 12
Bruce Bowker Round tail lights TVR 4
Cottontop Texas Healey Round Up 28 Austin Healey 0
jjbunn Another "Which way round" rubber seal question! Triumph 8
DrEntropy Alfa starter, round two! Other Cars 11
B Paint Round Two!! Racing 9
SS_MGB Wheel on the "B' go round & round MG 9
aeronca65t Round Engine Bike British Motorbikes 22
S Looking for a LHD year round something British Motor Corp 4
RickB Anyone use a Spridget as daily driver year round? Spridgets 27
DrEntropy Finally got that Round Tuit. Other Cars 3
drooartz Speed, round 2 Spridgets 17
A and the wheels go round and round MG 4
kennypinkerton Jaguar Saloon Drive Circles 'round the little guys Jaguar 4
Cottontop Texas Healey Round Up 26 Austin Healey 9
A Round 2, with one minor issue Spridgets 6
GreenHornet Round Trip Spridgets 1
G TR6 Another round of tires - TR6 16" wheel Triumph 10
V UK Shipping Cost - Round II Triumph 3
LastDeadLast TR6 Round driving lamps for 72 TR6 Triumph 17
Cottontop Texas Healey Round-Up 25 Austin Healey 0
Bret Smog Test Round #2 - A Happy Day! MG 0
