TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal???
karls59tr
Bronze
mctriumph
Use no sealers here but put anti seize on your studs, tighten properly. This is
also a great time to work the intake port on # 3 . It is almost always 2mm off set.
The factory was perfect on 1,2,4. but the jigs were off on 3. At least I have never seen
one that was good.(in the last 50yrs)
I use the al. foil method, to make a perfect template on the cylinder head.When transfered to the
manifold the problem is clear and easy to fix(drimill). FYI . Probably a coinkingdink but it seems
to be #3 that is the cylinder to fail when a motor blows up.
Mad dog
K
karls59tr
Bronze
Mad dog
I never knew that. I'll take out that 2 mil with a Dremel. I reordered the "upgraded" manifold gaskets from Moss. The fiber ones I got don't look heavy duty enough to seal the header I'm running. I want a good seal.
JHaydon
I've used fiber header gaskets on FF1600 racing engines. They work IF your header flange is thick and flatflatflat.
My header was, of course, NOT. I began blowing out gaskets after a couple of seasons (the section right between two neighboring ports, where there is no hardware keeping the flange tight to the head, just like what we have here!) Your first thought is "it wasn't tight enough," so you crank down a little harder next time, which warps the flange even more, making the problem worse.
Old-timers advised me to use copper RTV on both sides. It didn't fix the problem, although it probably would have helped a lot if the flange had been flat(ter).
I eventually found out about Remflex gaskets. Super-thick graphite gaskets that really really squash. That was the last header gasket I ever had to buy. I can't recommend them highly enough. It paid for itself pretty quickly.
Remflex Exhaust Gaskets
Remflex Triumph L4 Exhaust Gasket Set
They also offer the material in bulk so you can cut your own.
M TR2/3/3A Blown Exhaust Manifold Gaskets Triumph 10
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
mgedit TR2/3/3A Manifold Gaskets Triumph 4
af3683 TR2/3/3A TR3B Exhaust Manifold Gaskets Triumph 15
Patrick67BJ8 BJ8 - Intake Manifold, carb, gaskets sequence - Info needed Austin Healey 2
doughairfield Intake/exhaust manifold gaskets Triumph 1
B TR6 TR6 Manifold Gaskets Triumph 6
Simon TR4a Manifold gaskets, 4 cylider models. Triumph 1
RichC Manifold Gaskets MG 2
K TR2/3/3A Carbon buildup in an intake manifold and on spark plugs....... Triumph 3
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 12
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
A For Sale Mystery brass intake manifold Other British Classifieds 0
K TR2/3/3A Failed intake manifold gasket? Triumph 2
Carlbanan56 MGB Manifold plug MG 5
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
V MGB Replace late intake manifold angled breather with early model straight? MG 1
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
P MGB 1980 MGB Modified Intake Manifold MG 7
K For Sale Triumph TR3 Intake Manifold Triumph Classifieds 0
Ripper01 For Sale- TR-6 Intake Manifold Triumph Classifieds 0
M WANTED......Cannon Inlet Manifold Triumph Classifieds 0
9 For Sale: Thermocarb - complete setup including special manifold Austin Healey Classifieds 1
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
Ripper01 For Sale TR6 '69-72 Intake Manifold Stanpart V3108 Triumph Classifieds 0
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
steveg TR6 Fixing the intake manifold Triumph 8
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
B AH Spares Ltd. Inlet Manifold No. FUL 340 Austin Healey 2
Michael Oritt Intake manifold question Austin Healey 11
Michael Oritt Manifold Gasket Dressing/Sealant Recommendations Austin Healey 6
pbraun For Sale Weber downdraft Carb & manifold Spridgets Classified 3
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
D TR2/3/3A manifold studs..locktite or antiseize Triumph 5
steve00136 MGB Intake manifold alignment MG 4
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
Lin Intake manifold drain pipes Austin Healey 29
