Finally getting (re) started on the Bugeye
jholmgren
Happy New Year!
We bought our Sprite about 18 months ago. I had the engine rebuilt (bit beyond my capabilities), got it home and started tearing it down from the front to really get into the restoration. Can't put a freshly rebuilt engine into a nasty engine bay! Unfortunately last November I tore both my (L+R) rotator cuffs, so I've been out of commission for the better part of the year.
Finally got the lift cleared and my arms working - so yesterday I put the Sprite up so I can resume stripping the engine bay. I'm sure I'll have a lot of questions as I go - I have a good bit of familiarity with Spitfires, but this is my first Sprite.
First question - body panels. I see repair panels available from Bugeye Guys - any other sources I should be considering? I'm US based, so overseas shipping of larger panels 'may' be cost prohibitive.
Thanks!
Jim
JPSmit
Moss has them - though it might still be worth enquiring in the UK especially as there is a favourable exchange rate.
That said, there have been fitment issues with some of these. It may be worth casting around for some rust free (or rust freeish) original parts. Arizona maybe?
looks great on the hoist
J
jholmgren
Thanks for the suggestions guys - I will look into them, most of the panels I've fitted in the past were "ok" fitment, definitely needed some fettling to get straight.
Any opinions on Bugeye Guys as a source?
drooartz
I've used Bugeye Guy for a few things, been just fine. I would be surprised if most of their general parts are any different than what Moss has. They do seem to have some nicely curated parts, and a few things that do seem unique to them. I'll likely use them for some of the specialty bits, though probably Moss or British Parts Northwest for the general stuff as they're likely a bit cheaper.
J
jholmgren
Made some good progress today. Nothing fought me too badly, had to get the Dremel out for a couple of the P-clip screws, nothing too serious. Everything else came out with some PBlaster and elbow grease. I'll replace all the screws and bolts, but still bagged and tagged everything along with a bunch of pictures.
J
jholmgren
Good progress this weekend - interior is out and the dash is removed. Next session I'll start pulling the wiring back through the firewall and disconnect the hard lines.
drooartz
Good work. My Bugyeye is getting jealous of all this progress by other people.
Jim_Gruber
Bugeye Guy sources Rubber Parts from McGregors in Canada. Things like Windshield Gaskets, lower Cowl Gaskets, Door Seals, the McGregor Rubber Products work and fit correctly. In my experience Moss Rubber Stuff mentioned above does not fit properly. Bugeye Guy has been a valuable source for some specialty parts. Mini U Bolts for Rear Springs for example that are otherwise unobtanium.
J
jholmgren
Good information - thanks Jim!
J
jholmgren
Bit more progress today, nibbling away at it. Doors off, main harness out, wipers removed and a few other bits and pieces.
J
jholmgren
Continuing to nibble away - worked on the back end today. Got all the fixtures removed and the wiring harness out. Interior is completely stripped out and removed the steering column.
Jim_Gruber
Make sure you save the spacers under the steering column. Rebuild will need those in place to keep steering column aligned.
J
jholmgren
Yep - I saved those shims - everything gets an in-situ picture, then bagged and labeled whether I intend to re-use it or not.
J
jholmgren
Been a couple of weeks, but spent an hour or two nibbling away on the Sprite today. Got the exhaust, gas tank and e-brake removed.
BillyBud
I'm fairly sure Steelcraft makes all the replacement body panels and fittings including those marked as "British Motor Heritage". I had a conversation with Bugeyeguy about some less that stellar spring boxes I purchased from him (out of square, twisted, missing welds) and he claimed this was the case, one company made them all, so don't expect better anywhere else. My experience so far with Moss, AH spares (UK), bugeyeguy and others is that you should shop for price because what you'll get is all the same. I have replaced my rockers, floor pans, spring boxes, interior beams/braces, A pillars, and removed and patch paneled numerous rusted panel areas. Sometimes the parts fit well, but usually not, and require machining and reworking to fit. Be sure to inspect whatever you get soon and compare to the old parts. Unless it is a complicated piece like an inner A pillar you will probably be better off making your own. And that rust? It's everywhere.
J
jholmgren
There are at least 2 suppliers of sheet metal. I am familiar with Steelcraft from my Spitfire restoration. However, I did see a video online comparing replacement floor pans from 2 different sources and they were distinctly different.
BillyBud
And sometimes what you get in your order doesn't even resemble the photo/diagram on the website. I got two different versions of spring box braces, but I think they were just and earlier and later version made by the same manufacturer. One with holes, one without. Neither one was anything close to what the original looked like. Some of this inventory floats around for a long time before being sold. Good luck.
PS, who is the other manufacturer besides Steelcraft?
J
jholmgren
I had to figure out where I'd seen the comparison. Looks like a Canadian company: > VINTAGE SHEET METAL <
Saw it on YouTube:
J
jholmgren
Front end suspension tear-down is almost complete. Couldn't remove the springs via the "replace the spring plate bolts with longer ones" method because the two inboard bolts were totally frozen - on BOTH left and right sides. Heat, impact gun, penetrating fluid... nothing worked. Access is a little too limited to get a cutoff wheel in there to cut the bolts free.
I experimented with multiple options with no success. Stumbled upon a pair of mini-compressors designed for motorcycle springs - they fit the small springs on the Sprite perfectly. Had the spring out in 15 minutes with a very low "pucker factor".
J TR2/3/3A Finally getting started Triumph 20
JodyFKerr Finally getting started Austin Healey 1
Tr3aguy Finally getting round to it....help! Triumph 2
tsefreeflow Finally getting to the point.. Triumph 1
mctriumph TR2/3/3A Finally painted the 63 3b Triumph 14
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
Bayless More Sprite progress finally Spridgets 23
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
Bayless Progress finally begins Spridgets 5
tinman58 General TR Finally almost Triumph 7
Elva164 Finally did another onboard video! Racing 4
J It is driveable! Finally. Morris 8 Other British Cars 8
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
B Finally - BJ7 painted Austin Healey 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
R GT6 Finally Finishing Triumph 19
Sherlock It's driving season finally! Spotted 5
J Finally a fix for the SU pump Austin Healey 5
F MGB Finally got my 78 MGB on the road MG 5
