MGB A bit of disappointment
Platinum
The aftermarket shift boot only a few years old and hardly any actual "running time" since it was put in place, has split apart. As in disintegrated.
Order two if you're in the market for a replacement.
It is a definite frustration. Shouldn't be this hard to put together decent rubber bits nowadays, but I do understand that we're a tiny market.
A couple years ago I wanted to replace the heater valve on my Morris. I looked at the UK supplier and in their description of the part they said, right upfront, don't buy this, it's crap. :smile: They eventually found a better supplier, but I had to chuckle at the honesty.
At a point in the early '90's when those valves were Unobtanium I made a mold to cast Devcon rubber diaphragms. Now I've purchased a repro one and find it to be so stiff to move I fear it will trash the gear of the control in the dash. As the one on the head now has begun to leak onto the dizzy I will likely disassemble the "new" one and put the diaphragm in the old. If a different configuration, I'll break out the mold and get more Devcon casting rubber.
For a time we substituted a Ford in-line valve from an older truck. Required some fiddly modification to plumbing and cable, but it just WORKED.
The rubber may have been on a shelf for a long time. Never know.
This is part of the reason why I made leather boots for the shifter and brake lever on my TR4A. I used some thin goatskin leather that I had saved from previous work. I think they look and work better, too.
DrEntropy Bit of Historic Lotus News Lotus 0
DrEntropy Bit of nostalgia: Other Cars 14
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
JPSmit Interesting bit of trivia tonight Other British Cars 0
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
roscoe Distributor problem [a bit weird] Austin Healey 15
Gundy Runs a bit...then quits Spridgets 18
HealeyRick Runs a Bit - Then Quits Spridgets 23
Brinkerhoff TR4/4A Belgium built TR4A, is a bit unusual ! Triumph 16
Rut MGB Last little bit MG 0
I BJ8 is running a bit rough. . . Austin Healey 7
drooartz Bit of history on my new Bugeye Spridgets 0
B Engine Dieseling a Bit at Shut Down Austin Healey 12
M_and_P A bit of flex British Motor Corp 5
drooartz Off Topic Okay, this is a bit classier than the duct tape MG 4
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
G One bit the dust Triumph 12
drooartz A bit of workbench art MG 4
G Spitfire Bought a Spit today, a bit bummed out Triumph 12
T TR4/4A TR4A - A Type OD Solenoid - need a bit of help Triumph 7
RickB A bit scary this morning - ice Spridgets 22
KVH These Leaks are a Bit Shocking--Even for a TR Triumph 7
Hap Waldrop Acme Speed Shop just got a bit more speedy Spridgets 13
PC power bit to square drive socket adapters Restoration & Tools 3
Morris Had a bit of insomnia last night... Spridgets 3
glemon 11/64s drill bit tranny mounting trick Triumph 10
5 Is this bit off a healey? Austin Healey 8
jlaird Doing a bit of something. Spridgets 26
Wizardd MGB '77 MGB runs for a bit, then shuts down MG 28
angelfj1 PROJECT UPDATE - A Bit of Progress Triumph 13
drooartz Brosky, nice bit in the papers! Triumph 12
jlaird A bit of battery info Spridgets 4
drooartz Bit more progress tonight, nearly there Spridgets 21
Morris If only it were this easy...[ a bit OT ] Spridgets 5
W A bit more progress Spridgets 7
MGBGT_noob T-Series Clutch mater cylinder little plastickey bit MG 2
NutmegCT A bit of history Triumph 14
Tabcon A bit more restoration progress with pics. Triumph 24
W A bit of progress Spridgets 14
DrEntropy Bit of eye candy: Other Cars 26
mikecyc72usa A bit embarassing, this Triumph 2
Morris Bit OT: dangers of petrol Spridgets 8
eschneider help - what is this bit? [XKE, I think] Jaguar 6
1 Yeah! Finally bit the shock absorber bullet.... Spridgets 6
P power loss / bit of noise MG 13
jlaird Progress-well a bit Spridgets 2
