TR2/3/3A Passenger side fender mirror.......
You should be able to adjust it and when adjusted tighten the two little screws to hold it firm. However, because the mirror sits out over the fender, it is susceptible to being banged around as you or someone else (ie. car shows, etc.) walks near the car. If tightened too much, it could be broken if hit. To prevent this, I rotate the mirror inwards, so they do not hang out over the fenders. While the fender mirrors look great and are useful to view traffic on either side, I depend more on the rear view mirror. Hope this helps.
Honestly, the wing mounted mirrors are a losing proposition. Every wing I have owned (8 wings over 2 restorations) have had at least 3 holes where the mirrors were installed, broken out, relocated, broken out, etc. There is too much vibration for 18gage steel to support. Now, if you could mount a steel backing plate to distribute the load, I think it would be more stable and hold an alignment better...but that is something you would have to do during a paint job.
It looks like you have done away with them entirely in your profile pic. Probably safer to shoulder check anyway than to relay on the wing mirror.
I could not keep mine adjusted and if I could do it over I would have welded the holes up.
Made a mirror mount that goes n the windscreen stanchion. It works well and I can adjust it as I drive if I have to. It is also a convex mirror which helps a great deal. The mirror on the wing is flat so it has a very small field of view.
David
Made a mirror mount that goes n the windscreen stanchion. It works well and I can adjust it as I drive if I have to. It is also a convex mirror which helps a great deal. The mirror on the wing is flat so it has a very small field of view.View attachment 68174
David
Is that a self tapping screw holding the mirror bracket to the stanchion? I'm wondering if that setup would work on the passenger side because of the angle of site? I think I saw where someone had mounted a Harley Davidson mirror to the stanchion....have you ever seen that?
I refused to install fender mirrors on my TF since it never had them and I didn't want to drill holes in my perfect fenders. So I bought a pair of these from Moss and love them! If the windscreen is down, they can be rotated and still used. PJ
It is a Chrome Button head socket cap screw that matches the Stanchion mounting nut. I bought a pack of 10 from Mc Master Carr. Works great. Bent up the SS bracket from some material I had in the shop.
PM if you need one.
David
Here’s my solution, which I spotted on an MGA on the web. I used one existing hole, and drilled and tapped another (using a BA tap), plus some extra strong clear epoxy. I really like the results!
I have to say there some great looking cars and great ideas on a common problem and your pic are great also.
Basil you might think of setting up a thread of pic of this and other parts, Like say dashes or wiring up-dates. radios. Things that were mist in the 40's 50's 60's 70's and 80's
Madflyer
I used one of the fender mirrors. The stud on the original mirror is too short, so I cut it off, drilled and threaded a 5/16"-24 hole and screwed in a stud long enough to screw into the one of the stanchion holes. This will only work with the non-dzus stanchions. I still have both fender mirrors, and unless I bump into them, they stay put. Both fender mirrors are convex and the stanchion mirror is flat. That gives me a great view to the sides.
That looks like a great way to solve the problem. It dosn't look like the wind wings would fit after that mod though? Guess a person just goes for one or the other.
I agree that the wing mirrors are a RPIA (R = royal). I first endured them on an MGA Twin Cam back in the 70s and they were useless then and they are useless now, but I still like them vintage-appearance-wise. Plus, I have two very nice holes in my fenders/wings and something needs to go there other than the diplomatic flags of friendly nations.
Interestingly, the windscreen stanchion mount derives from early convex mirrors on the Model T Ford where they were frequently built into the backs of stanchion mounted spotlights.
I was never a fan of the wind wings, so the thought of the mirror interfering hadn't crossed my mind. I suppose the mirror could be mounted in the front screw hole of the stanchion. That might work.
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
Jim_Stevens TR2/3/3A Firewall passenger side Triumph 2
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
D Poor fit door and glas to top on passenger side. Austin Healey 7
Geo Hahn Lowering Passenger Side Ride Height on non-IRS TR Triumph 4
T TR6 Passenger side TR6 rear clunk? Triumph 9
D Spitfire WTB window regulator, passenger side, '65 Spitfire Triumph 3
T Wedge TR8 scraping noise from the passenger side rear Triumph 10
I Need tracing for passenger side 69-72 kidney pad Triumph 7
MadRiver New Clunking Noise from the Passenger Side Triumph 2
TNMGB Rattle on rear passenger side MG 17
mabbott TR6 TR6 passenger side rear rattle/clunk? Triumph 11
M USELESS PASSENGER SIDE BULLIT MIRROR FIX Triumph 21
msoylemez wiring harness on passenger side Spridgets 5
Musicman Installing Passenger Side Mirror Triumph 7
J Passenger side water leak MG 3
LAW75 Driver's and Passenger's Floor Carpets Austin Healey 7
P TR6 1970 TR6 Passenger Sun Visor Replacement Triumph 1
charlie74 Wanted Passenger seat replacement foam [‘74] Triumph Classifieds 0
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
S TR2/3/3A passenger door Triumph 24
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
B Wanted TR250 passenger seat Triumph Classifieds 0
A TR6 '73 tr6 passenger front brake dragging Triumph 2
Jim_Gruber BE Passenger seat bases Spridgets 6
B Passenger interior door handle issue [1960 BT-7] Austin Healey 4
richberman Longbridge passenger lock chrome lever anyone? Austin Healey 8
Tr3aguy TR2/3/3A Looking for a passenger door!!! TR3 Triumph 20
Boink Passenger Parcel Shelf in a Bugeye Spridgets 25
H Tailpipe exhaust back into passenger compartment Austin Healey 26
brgrmyster GT6 GT6 Mk 1 Passenger Foot Rest? Triumph 3
JBann Spitfire Rear passenger brake drum smoking - Mk1 Spitfire Triumph 4
Tinkerman TR2/3/3A TR 3A Passenger Seat Tilt Forward Bolts Triumph 3
J BJ8 passenger foot well [LHD], right wall Austin Healey 1
S MGB Removing the passenger seat from my 71 MGB..... MG 4
T Wedge TR8 passenger floor - advice needed Triumph 7
Number_6 TR2/3/3A TR3A Passenger door Triumph 11
N TR6 TR6 Passenger door and window fit ? Triumph 5
regularman Is there room under the passenger seat.... Spridgets 11
X Sagging passenger door MG 14
Got_All_4 TR6 1969 Triumph TR6 passenger seat Triumph 13
B Passenger seat is derusted and primed!! Spridgets 3
M 87 XJ6 Driver and Passenger Footwell Water Leaks Jaguar 2
