BJ7 -lost reverse, then 3rd/4th - advice please!
twas_brillig
Picked up the grand daughter from school today and there was no reverse available when I backed out of our driveway - lever moved okay to the left, but only pulled back an eighth of inch or so - felt like there some hard rubber plug stopping it. Tried again later and lifted the clutch a bit and got 'grinding not fully engaged' noises. Drove down to the school fine, parked, played in the playground, then found no 3rd/4th on the way home - similar issue: lever moves to the right okay, but won't slide fore or aft. It's a centre shift BJ7 with o/d.
My Haynes manual says nothing regards diagnosing/adjusting linkages (I'm assuming that's the problem)and I'm off to borrow back my Bentley manual. Plan had been to drive it north (300 km) Monday for winter storage, but I'd prefer to have more gears.
As a back up to the Bentley manual, I'd sure appreciate some advice. It's quit raining here but we're hitting freezing at night, so these driveway projects are less fun. I drove it up on ramps yesterday for an oil change, so there may have been some stressors from frame flex.
Doug
At the very least, you'll need to remove the fibreglas cover over the trans, and then remove the top cover, lever and all.
I suspect that whatever's wrong, will start to be obvious at that point.
If you can take digital pictures of what you find, we can probably add more suggestions to help you out. If you can't post the pictures here, send them to me and I will put them up for you.
But I agree, it sounds like a control linkage problem.
Thanks for the thoughts Randy. Gonna head over to the shop that's borrowed my Bentley manual first thing tomorrow (they were closed when I got there today at 4:30, as was the shop I was hoping to maybe take the car into), then the repair shop, then home. Pull the carpeting; remove the trans cover; pull the shift lever extension; avoid dropping any springs and pieces, and look for a sheared pin or some such.
Doug
Doug,
My first check would be the split brass bushing at the small ball end of the shift lever before removal of the top cover.
Put the shift ball back on the shift lever after you remove the fiberglass cover, remove the snap ring retainer, the spring will pop up with washers/shims, remove the shift ball and retainer parts.
Put the shift ball back on the lever and pull up to pop it out, you'll see the split bushing held on with a small retainer.
Order a replacement to remove shift lever slop since it's easy to replace and a cheap part.
Tom
Thanks Tom - got the manual back this am; the repair shop will take the car first thing Monday am if I can't figure it out; the shop in Edmonton that did a lot of work a couple of years back suggested checking the 'Selector lever and change speed lever socket key', item 114 on page FFF.5, of the Bentley reprint and the original shop manual. So: off with the carpet; off with the trans cover; check item 114, then check the lever bush (item 116) per Tom, then maybe put it back together and let the professionals have a look. At least the shop mechanic is older than the car and has an aceent to match it.
Thanks
Doug
Resolved (I think!): pulled the carpeting and removed the transmission cover; removed the circlip/washer/spring that hold the shift lever solidly in place; and found that I had all my gears working if I lifted up on the lever while shifting. And accidentally pulled the lever right out of the housing!
The manual shows two roll pins that fit through the casting and into vertical slots on either side of the shift lever and presumably help locate it and prevent it from pulled straight out. I've got the two roll pins, but one of them was too short to actually fit into its matching slot and presumably allowed more play in the linkage than should have been there.
The manual advises that you can tap the roll pins all the way into a hole within the shift lever so that you can remove it - note that this hole is slightly above the bottom of the slots, so (should you need to pull your lever) don't just starting whaling away with the big hammer and small drift.
I'll head north tomorrow and plan on maybe having to fiddle a bit on my shifts, but at least it's not the gearbox. And thanks Tom and Ray for the thoughts.
Doug
Made it north to storage today; no problems shifting and the car ran fine, except the overdrive went away about a half hour from the end. Started off wearing a pile layer and goretex over that with a temperature of +9C (top down); down to shirt sleeves at the half way point and was darn near sweating at the end at 23C (73F) - it's been a cool, wet summer. So, will ask the shop to check out the o/d as well as the roll pins; if I ever put in the Toyota trans, I'm really going to miss flipping that little switch back and forth!
Doug
Shoot! I'm happy as a clam with your suggestions, and that I lucked out!
Thanks again,
Doug
Hi Doug
Check oil level in gear box to see if that is cause of your OD loss, mine needs to be run slightly over full to get OD reliably.
Ian Irving
Doug,
Had the od go out on me about 6 months ago. First thing I check is electrical and I pulled the flippin little switch out of the dash. Sure enough it did not have continuity when switched on. Ordered a new one and checked it with the multimeter before installing - didn't work. Ordered another and it now works fine.
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Door Seal Austin Healey 5
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
D BJ7 Hood frame mounting plate Austin Healey 7
D Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
T Installing Garmin GPS in a BJ7 Austin Healey 19
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
P BJ7 Upholstery Austin Healey 1
B BJ7 back end rebuild Austin Healey 1
Marvin Gruber BJ7 door panels Austin Healey 4
Marvin Gruber BJ7 Top Installation Austin Healey 1
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Marvin Gruber BJ7 tach cable location. Austin Healey 3
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
