LEERIVAS said:
			Fantastic Video...The really impressive part is viewing all of the upgrades you added while still keeping the originality of the Healey design.
Am I to believe that you did this without upgrading to an alternator?
I'm still rebuilding my 60 BT7, which I've had in in my garage since 1971, to it's original "splendor" and must decide whether to go negative ground and whether to "upgrade" to an alternator.
Does anyone know if it's technologically possible to "gut" the generator and replace it with a small alternator?
Hello Leerivas,
Thank you for your kind words.
I am fortunate to have two great Healey mechanics in my area. I questioned both of them about changing out the generator to an alternator because of the additions to my car.  They both mentioned that it depends on the load or drain I'm putting on my system.
I know both of my mechanics like keeping the car stock.  And one of them shakes his head when I say, guess what's new in my Healey.  This is the same guy that finds fault because my engine compartment is too clean.  Yes, too clean.  And he tells me to stop baby-ing the car.  I like this guy! Last time I was over there, I said to him, hey I took the Healey out for a spin this morning.  I drove it like I stole it! What's his reply?  Again, with the head shake.  I like this guy!
OK, back to the point about my mechanics like a stock car. As I've mentioned in a lot of my posts and on my Youtube video, what I add, I try to conceal. If it's electrical, how much load will it put on my battery/generator.  I like the look of that generator in there.  And as my mechanics explained to me, I only need to replace it with an alternator if I put something in the system that draws more than the generator can replace.  Other may chime in on this.
An example would be a stereo amplifier.  The bigger it is, the more it will drain.  I don't have that. I have two sets of computer speakers running my nav/mp3 system. Each set has an amp built into the speaker. Of everything electrical I have added, those draw the most power. Which is hardly anything. Both my mechanics know what I have and say I'm fine.  They say the thing to watch for with a generator is when I'm, or anyone with a Healey, is when your running everything. Headlights, heater, windscreen wipers, dash lights, fog lights, stock am radio, directional's for an extended period of time.  The generator may not be able to put that load back to the battery. Let's say in a lot of stop and go traffic.
I did change my car to negative ground. It did make adding electrical items, not as much a challenge. Plus, you can not see the change to negative.
"Gut" the generator and replace with a small alternator?  Yes, and here is a link to Gener-Nator who makes such a product.
https://www.gener-nator.com/details.htm
Cheers,
Roger
