TR2/3/3A Yet Another TR3A Slave Cyl Question
Geo Hahn
The slave cylinder set-up on my TR3A looks different from the manual (lots more pushrod needed on mine):
As you can see I do not use the return spring. The clutch works fine w/o it -- doesn't work at all with the spring connected.
Why?
I think I know the answer but hoping I'm wrong. The good news is that I've driven it like this for more than 30 years.
Hmm. Broken fork pin, or bad replacement throwout arm? Or worn fingers on the pressure plate? I'm not coming up with anything good!
First of all, these did not come with self-adjusting clutch hydraulics. Simply removing the spring does that (and sometimes allows the throwout bearing to sing on the pressure plate fingers).
To see the clutch arm that far back would mean some things to look at.
Partially sheared pin on the fork, excessive surfacing of the flywheel, wrong or worn pressure plate and/or disc, thrust washers?
On these cars, the piston bottoms in the bore, you set the adjustment with the your finger holding the arm back, check for looseness, then install the spring and check for free play.
Self-adjusting only have free play if there is a lot of wear between pedal and master piston.
No idea how far out your piston is now, but visually drawing a line down the pushrod to where the center line of the slave housing is, looks like a long way.
Spirited driving, without a spring, you may end up with the slave piston hanging out then end and no clutch at all.
I have seen that before....not on a TR that I can recall, but I've seen it, after we got the car pushed into the shop off the wrecker.
Me? I'd want to know why that arm is as far back as it is.
Dave
:iagree:
Well, mostly anyway. I set my free play with the spring installed, cause it's such a pain to R&R the spring :smile:
pkmh Yet Another Oil Question! Austin Healey 8
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
PC yet another Opel Spotted 0
blumagnet yet another Flame Thrower conversion Spridgets 4
Jim_Newman Yet another muffler question. Austin Healey 3
RickB Yet Another Spridget on Seattle Craigslist Spridgets 2
Sarastro Yet another super-cheap Spridget! Spridgets 8
T TR2/3/3A yet another TR3 steering box question/hone? Triumph 9
W Yet another yellow steering arm Spridgets 1
T TR6 Yet another TR6 post Triumph 5
Dave Richards Yet Another Tire Size Question Austin Healey 11
Sarastro Yet another alternator conversion Spridgets 10
Bret Yet another sneak peek into the.... MG 13
Bret Yet another Zenith Stromberg replacement choice MG 6
Camshaft Yet another Saab Shelby wheel question[s] MG 14
angelfj1 SORRY - YET ANOTHER TIRE QUESTION Triumph 2
W yet another BMH trust certificate question Austin Healey 5
coldplugs Yet another mystery car Other British Cars 31
Sarastro Yet another odd clutch problem. Spridgets 5
B Yet another road trip. Spridgets 16
MrPandy Yet another gauge question Triumph 9
catfood Yet another new Healey Austin Healey 2
coldplugs Yet another mystery car photo Other Cars 17
BritBox Yet another TR clutch issue Triumph 24
M TR2/3/3A Yet another TR3 question... Triumph 3
G Yet another Ebay rarity Triumph 10
Nunyas Yet another choke inquery... MG 8
B Yet another Newbie MG 17
Webb Sledge Yet another Triumph question Triumph 4
UltimateQuestion Yet another Miata-based counterfeit Other Cars 8
Johnny Can I add to an article that I've completed but not yet published? FORUM Navigation Questions 2
doc50 TR2/3/3A DIDN'T BLOW the OD up [yet] Triumph 6
G TR4/4A Anyone know if this car has sold yet? Triumph 0
jhorton3 Best MG Drive Day Yet Spridgets 0
B Second picture. I don't quite get this yet Triumph 1
JPSmit Is it Halloween yet? Spotted 9
jlaird Got your attention yet or Spridgets 11
T TR2/3/3A Tush - TR3a louvres or not? Color picked out yet? Triumph 15
T Yet one more bushing question - which to order Spridgets 4
charlie74 tansmission question [not problem, yet] Triumph 14
T block prep progress-slow and not finished yet-pics Triumph 3
Sherlock A Sunbeam, but yet other British cars... Other British Cars 14
2wrench Simple yet important engine timing questions Triumph 11
regularman Shortening the list of things yet to be done. Spridgets 14
Brosky Are you signed up for a "subscription" yet?? Triumph 92
budk1953 Running, but not singing - yet Spridgets 3
Trevor Jessie I don't know if has been mentioned yet... MG 0
fmichaels not stumped yet .. but Spridgets 26
jlaird Tony you do it yet. MG 6
F Someone have new floorpans not installed yet??? Spridgets 5
