yet another Flame Thrower conversion
blumagnet
I realize I may be beating a dead horse, as there has been a lot of input regarding electronic ignitions on this forum. However, I am wondering if there have been any new technological advancements since some of these older posts. I am planning on installing a Flame Thrower distributor in my 1275. I have a Lucas sport coil, but after reading some of the older posts, it sounds as though replacing that with a Petronix ignition coil at the same time wouldn't be a bad idea. It also sounds like I will need different plug & coil wires than the stock Lucas replacement wires & cap I have on hand (right angle, but the new distributor has the straight cap); any suggestions which wires are best? I would like to think this is the last journey through the ignition system I may need for a while & would like to upgrade to the most reliable modern technology out there. What do you think is the best combination of ignition components? What about plugs? I have been using NGK BP6ES with better results than Champion N9Y and wonder if there are even more advanced replacements (EC3?)
Apologies in advance if I have insulted any purists by suggesting non-stock alternatives...
No worries, none here. :eagerness: I use solid copper sore Accels but I don't use the radio and I wouldn't put Champions in my lawnmower. I got the universal V8 set for $20 which allows me to make two sets of wires. I should be good on wires for the rest of my life.
When in doubt about ignition systems, ask Jeff at Adavanced Distributor. He sells (and I use) the Bosch wires with right angle ends, his red rotors and this Dizzy Cap with Brass contacts. .. on a Crane system, but I find this stuff to be the best available.
Blu - I too thought I wanted a Pertronix dizzy..and bought one. When I went to install, I was less than impressed with the fit of the dizzy cap (and it's specific to their distributor) it could rotate 2-4 Deg once 'in place' and was generally loose in my opinion.
I ended up ditching it and having Jeff rebuild my Lucas Dizzy with a Pertronix module.. Which I would highly recommend. For the same (or less) money, Jeff will set your dizzy up to your engine configuration..with a proper rebuilt unit.
pkmh Yet Another Oil Question! Austin Healey 8
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
PC yet another Opel Spotted 0
Geo Hahn TR2/3/3A Yet Another TR3A Slave Cyl Question Triumph 4
Jim_Newman Yet another muffler question. Austin Healey 3
RickB Yet Another Spridget on Seattle Craigslist Spridgets 2
Sarastro Yet another super-cheap Spridget! Spridgets 8
T TR2/3/3A yet another TR3 steering box question/hone? Triumph 9
W Yet another yellow steering arm Spridgets 1
T TR6 Yet another TR6 post Triumph 5
Dave Richards Yet Another Tire Size Question Austin Healey 11
Sarastro Yet another alternator conversion Spridgets 10
Bret Yet another sneak peek into the.... MG 13
Bret Yet another Zenith Stromberg replacement choice MG 6
Camshaft Yet another Saab Shelby wheel question[s] MG 14
angelfj1 SORRY - YET ANOTHER TIRE QUESTION Triumph 2
W yet another BMH trust certificate question Austin Healey 5
coldplugs Yet another mystery car Other British Cars 31
Sarastro Yet another odd clutch problem. Spridgets 5
B Yet another road trip. Spridgets 16
MrPandy Yet another gauge question Triumph 9
catfood Yet another new Healey Austin Healey 2
coldplugs Yet another mystery car photo Other Cars 17
BritBox Yet another TR clutch issue Triumph 24
M TR2/3/3A Yet another TR3 question... Triumph 3
G Yet another Ebay rarity Triumph 10
Nunyas Yet another choke inquery... MG 8
B Yet another Newbie MG 17
Webb Sledge Yet another Triumph question Triumph 4
UltimateQuestion Yet another Miata-based counterfeit Other Cars 8
Johnny Can I add to an article that I've completed but not yet published? FORUM Navigation Questions 2
doc50 TR2/3/3A DIDN'T BLOW the OD up [yet] Triumph 6
G TR4/4A Anyone know if this car has sold yet? Triumph 0
jhorton3 Best MG Drive Day Yet Spridgets 0
B Second picture. I don't quite get this yet Triumph 1
JPSmit Is it Halloween yet? Spotted 9
jlaird Got your attention yet or Spridgets 11
T TR2/3/3A Tush - TR3a louvres or not? Color picked out yet? Triumph 15
T Yet one more bushing question - which to order Spridgets 4
charlie74 tansmission question [not problem, yet] Triumph 14
T block prep progress-slow and not finished yet-pics Triumph 3
Sherlock A Sunbeam, but yet other British cars... Other British Cars 14
2wrench Simple yet important engine timing questions Triumph 11
regularman Shortening the list of things yet to be done. Spridgets 14
Brosky Are you signed up for a "subscription" yet?? Triumph 92
budk1953 Running, but not singing - yet Spridgets 3
Trevor Jessie I don't know if has been mentioned yet... MG 0
fmichaels not stumped yet .. but Spridgets 26
jlaird Tony you do it yet. MG 6
F Someone have new floorpans not installed yet??? Spridgets 5
