regularman
Jim_Gruber said:Kim,
When you repainted your wheels did you use a stencil or was all that free hand. I've got to repaint my Rostyles and replace trim rings on Bugsy.
That's easy to fix!Rik said:Kim,
That doesn't look at all like your car. It has a mirror on the passenger side.
Rik
Yep, everyone seems to notice that. I just never needed one. Plus no chrome trim rings on the wheel and no white letters :wink:Rik said:Kim,
Rik
I took the tires off and sand blasted the wheels in one of those little blast boxes with the glove arms made into it. Then I painted it gloss black rustoleum, then I used plain 3/8 inch wide masking tape and hand painted the silver. I took a silver spray can and just sprayed it into the lid and then dipped the brush in that and painted it. When it was dry, I peeled off the tape and did a bit of touch up and then sprayed some rustoleum clear over it. Not real happy with the clear. It wrinkled in a few places. I did all five wheels that way. The early rostyles were harder to paint than I think the later rostyles would be. I got a set of the later ones on the junker and might paint them. I still got that paint that has 97% of the reflectivity of real chrome.Jim_Gruber said:Kim,
175/70/13 and they are no longer made. My toe in was way out and ate the front tires up while the back ones have almost no wear at all. I need two tires but they are not to be found. I may have to swap the two rears to black walls and get some different ones for the front.Jim_Gruber said:Kim, I agree your Rostyles look awesome. Bugsy is definitely envious of your wheels. Hey I think your Spridget is a SWA. What size tires are those Firehawks?
Hey man, how you doing? I will check that one out for sure. I went on a trip with the wife to the outer banks on sort of short notice. I was thinking about you but could not remember where you were from there.leecreek said:
