The water valve to the heater core in Baby Blue sprung a leak out of the spigot (screw) portion of the valve. It doesn't matter if I have the valve open or closed, it still leaks. As a temporary fix, I put some sealant around the spigot. It's a very inelegant fix, but it is an effective one. I do have a new valve ready to go. Is this a situation where I'm going to have to drain off the antifreeze to make the fix, or is this something I can do with the antifreeze still in? I imagine I'm going to make a bit of a mess, which I don't mind. Dropping half the coolant on the ground, though, is probably not what I'd want.
Right now, as long as my temporary fix holds, I'm content just to drive the car and wait until winter when I'll do another round of heavy maintenance on the car where I'll be changing out the antifreeze anyway.
