Hello Everyone,
I know woodworking is not a common subject on the forum, but I need some woodworking help with my dash. I have some rosewood veneer from the top of an old piano that was broken apart years ago. I sawed it in half and was able to plane it down to about 1/16th of an inch. The core it was attached to was oak. The dash I used to reface was badly damaged and slightly warped to begin with; I should have just started with a different dash. After a few months of installing my beautiful rosewood dash, it started to crack as the dash started to warp again. I am going to start this process again with a dash I got cheap off Ebay that is in fairly good shape. On my last attempt the rosewood veneer still had oak behind it because I could not plane it any thinner, and it was difficult to cut out the glove box and other areas. I figure if I can get it sanded down to 1/32 (so that there is only rosewood veneer) it will be easier to cut and be less likely to crack if there is any movement. Does anyone know if this can be done, who does it, and the cost?
Thanks,
Kevin
Thanks,
Kevin
Hi Guest!
