MGB Under-hood insulation on the MGB
William
So, attached to the underside of the hood of Dad's B is that silvery bubblewrap heat shielding stuff. It was never glued in or anything, just cut to fit and held in place by the underhood structure. The heat (ha!) and exhaust gases seem to have gotten to it, and it keeps falling off (right onto the carbs!). So Dad pulled it out the other day.
I'm pretty sure that it's not an original item for a '71 B. Does this stuff have any real benefit? I would think it's keeping the hot air in even more, even though it's "reflecting" the heat.
Should we go buy more and put it back in?
-William
the original heat shielding should be a black cover with a burlap colored fiber under it. The main purpose of the stuff the best I can tell is to keep the paint on the hood from bubbling up. Moss or VB sells the original style pads and on eBay there are some very nice looking pads with a MG logo on them. They should be glued on.
The underside of my bonnet was furry from that fibrous stuff. I pulled the bonnet off the car for other reasons, then spent several hours with a bottle of Goof Off and a plastic chisel de-furring. I found rust that could not be seen with the glue in place, likely saved more work down the road on the bonnet as I hadn't planned to touch it for quite a while. I'm almost ready to prime and paint, then I've a pair of those mylar bubble insulation panels that you describe (came with the car). May velcro them in or something. Heck, they're taking up space OUTSIDE the car at the moment; might as well do something with 'em. What I will NOT do is squirt glue around at random and squish the mylar in place.
It's amazing, by the way, what cleaning up the underside of the bonnet does for the aesthetics of the engine compartment.
Tim
The insulation will do a few things...
1. Reduces hood (bonnet) temperature, which protects paintwork and lowers temperature of air entering the fresh air vent.
2. Reduces hood vibration
3. Reduces engine noise heard from outside of vehicle.
Original material replacement is pretty inexpensive. For about $10 more you can get this modern material that looks a little better. Use 3M adhesive #90 to attach. See below.
I got mine from Jeff Zorn at Little British Car Company. I also see them on e-bay from time to time.
Thanks for the replies! I think Dad actually stuffed the insulation in the trunk, so we can't even claim we removed it to reduce weight!
I'm quite sure that the orignal shielding disappeared when the car was repainted by the PO, as there's no sign of glue or fur on the underside of the hood. Don't think it did any good either cause the paint has a blister on it. We'll probably buy some more when the car gets repainted and re-install.
Good idea on the Velcro.
-William
The other advantage to some kind of insulation on hte underside of the hood is that if some debris is kicked up to where the fan gets hold of it, it can be thrown against the under side of the hood hard enough to cause a reverse rock chip in the hood. I got several ugly stars on the front of the hood from just such encounters before I got smart and installed the insulating material.
Cheers,
I used rhino lining as an under bonnet insulator it has worked fine for several years and is no worse for wear the original insulation is known to sag and the replacement pieces do not seem to fit as the original did
I know it would probably be overkill, but some Dynamat would serve the same purpose (albeit more expensive). I have some of the stuff on my firewall and the tops of the foot wells. I know it helped quite a bit with the heat transferred into the cockpit, but it is a bit expensive.
D TR2/3/3A Under hood Photos Triumph 7
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
T General MG Pressure washing under the hood? MG 11
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
andrea OIL sprayed on the under hood-TOP oil filler indaghed Austin Healey 26
CZ_Dave FIRE! Under the HOOD! Other Cars 11
K gloss paint bj8 under hood Austin Healey 9
bigjones Spare coil - put it under the hood? Spridgets 8
Stinger TR4/4A TR4A Under Hood Grease Pencil Markings Triumph 14
tony barnhill Under Hood Paint Questions Spridgets 7
wkilleffer Under the hood grounding point MG 11
jackq counter under the hood MG 10
H What is it? Counter under hood MG 15
H What is it? Counter under hood MG 27
1 Simple question: what is this under the hood? MG 13
Guinn Smoke under the hood MG 2
J A strange sound from under the hood! Austin Healey 18
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
DrEntropy Show this to anyone under 40... Restoration & Tools 9
M MGC New book: MGCs Down Under MG 0
R Ground wires under dash Spridgets 5
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
J TR2/3/3A Pads under new floor Triumph 7
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Rust under flanges Triumph 7
B Under bonnet fuel Austin Healey 15
D MGB Stopping rust under patch panels MG 1
T Coroplast Signs under Wheels Austin Healey 0
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
C Under boot and under bonnet paint? Austin Healey 7
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A Under the dash re-assembly sequence Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
B MGA What does this founder mark mean? MG 4
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
Sopwith_Camel MGB under or over MG 3
G Supplier rant from down under Austin Healey 12
D Lilly under her own power... Austin Healey 7
G TR4/4A Under Dash Pics Triumph 2
LarryK TR2/3/3A Craigslist St. Louis under 1959 Austin, Jag, Triumph Triumph 2
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
K TR3A Air vent under grille on Race Cars? Racing 5
D TR4/4A shims under axle housing Triumph 7
simon1966 BN1 Strip down well under way Austin Healey 5
