AN5Sprite
So... When I bought the Tunebug from Drew I purchased it knowing it had some "tuning issues". The issue as described was a high speed miss. Specifically at 3k it just began to run poorly and didn't want to rev. Sure enough, I experienced the same thing and began hunting for vacuum leaks. I found two possible leaks. Fixed them. No improvement. Ok....I go over the ignition sytem, carbs, valve adjustment, fuel filter, etc. I made a few adjustments, with no improvement on the problem. I'm confident everything is right. No vacuum leaks, idles fine, exhaust note seems fine to me, the plugs couldn't look any better. I hooked up a vacuum gauge to the intake. The reading is lower than it should be and the needle flickers fast. I'm not totally sure what that tells me other than it's a problem that's effecting one cylinder. Moving on to a compression test. I get 175psi on cylinders 2, 3 and 4 but only 100psi on 1. Here's the thing; there's no white foam under the valve cover, no water in the oil, no oil on the water. No over-heating. Low compression in #1 and no ability to rev under a load...
My questions:
1. Is there a way I might get out of this without pulling the head? I can't see one, but if there's a way I'd like to hear about it. Before I pull the head I want to know I have no other choice.
2. Is it possible to have a head gasket fail and not have over-heating, contaminated fluids etc? (...is it just beginning to fail, and the other symptoms come later if left alone?)
3. What's your guess as to what I find? Head gasket failure or something worse?
My questions:
Hi Guest!
