Well, I know it's not all that exciting.
But I have two leaks from the overdrive unit in my TR4A. As Randall suspected, neither has anything to do with the silver BBs or freeze plug.
The first is not so unusual--dripping from the OD drain plug. I'll mess with that as best I can.
The second is from a small lever on the passenger side of the OD housing. Moss seems to refer to that piece in a Troubleshooting Note as the "adjustment setting lever."
Anyway, I assume I can't do anything about this leak short of pulling the transmission. I can't tell from the Moss drawings but there may be an 0-Ring or bushing for the shaft.
I've lost 6 ounces of fluid while the car sat for 4 months, so this definitely is a constant drip. I'd guess half from the plug and half from this little lever.
I'll follow any good advice (like forget it, drive, top up, drive).
