Kleykamp
Two catalogs show the mounting bolt going thru the tail ext of the transmission with the nut under the mount, then the gearbox mount has two nuts that screw UP from the bottom to secure on the underside of the plate. Here's the problem, someone DPO put the bolt going UP from under the gearbox mount, thru the tail ext and nuts on top. It seems that the tail ext will not lift high enough to clear the bolts,in order to pull the trans up and out, and I can not turn the mount to get it out of the way. Basically the bolts are wedging everything. The bolts do drop down so that they are even with the top of the tail ext. question is: will the trans lift enough to clear the bolts and slide back. I'm doing this alone, so I don't want to have my hands full of transmission and not be able to turn loose. I have a jack under the oil pan and another under the trans, trying to carry the weight partially. Suggestions??? This is the 3rd time i've pulled a trans, but previous cars had the bolts in from the top, so this was not a problem.
