Deleted member 8064
TR6 Startup up-date
Well I started the engine again after correcting fuel and water leaks...nothing major. I gave it the 20-25 minutes at 2000-2500 rpm as recommended by some. Thanks. I had to have full choke on the carbs to maintain the engine on. After warming up I would release the chokes and the engine would stall. I also have an oil leak at the front. It seams to be by the timing cover at the bottom. How do I know if its the gasket or the seal?
Thanks in advance.
Vic
Guayama, PR
Thanks in advance.
Vic
Guayama, PR
