I'm curious what others have done in the area where the channel next to the bonnet seal ends against the front wing on a TR6. This channel collects water from the bonnet and the scuttle panel on the outside of the car. It appears this area dumps water right into the infamous area where the scuttle drain empties. As I disassemble, I find a previous tinkerer sealed this area with a sticky rubber type caulk, leaving the water to dribble around under the wiper motor. Another question is the seal between the wings and the inner panels. If I don't use something there, won't water ooze through from the wheel. and sit there? How about some butyl tape, or ??
Thanks,
Dennis
Thanks,
Dennis
