bash
I noticed the other day that the indicators on my '75 TR6 weren't working. Trying to trace the problem this evening as I promised my daughter I would drive her to school in the morning. I now find that the brake lights aren't working either. I figured this meant a blown fuse - I have Dan master's book and the Advance Wire schematic and see that the green fuse feeds both brake lights and indicators, but the fuse is fine (no sign of damage and I tried a good spare), and on further investigation found that the reverse lights work fine, so the fuse and power to the fuse must be okay. I know that the indicator bulbs are okay, as the hazard switch brings them all on, though at about double the normal frequency. I have yet to test the brake switch at the pedal, but that won't cure the indicators as well. It could be two separate problems, but I am hoping that someone out there will have some ideas on how to sort this out! Main points:
* indicators don't work - left or right
* brake lights don't work
* hazard lights flash at double speed
* reverse lights work
* tail lights work (which I think rules out bad ground at the brake light bulb?)
Thanks in advance for any help
Alistair
Alistair
Hi Guest!
