Hi- New member here.
So my '74 TR6 is going to get a new cam! I am closing in on removing the timig cover to access the old cam... I am not sure how to remove the large bolt that holds the pully wheel onto the crank. Naturally when I try to loosen it, the engine wants to turn as well. What is the generally accepted way of immobilizing the engine so I can loosen the bolt?
The engine has a nice finish so I dont want to put any tooling marks on it if possible. I suppose I can remove the starter and jam a screwdriver in a tooth of the ring gear... Is there a better way?
Also, does anyone know what size socket fits the head of that bolt?
Thanks,
Steve
Thanks,
Steve
