TR6 TR6/250 water pumps and a dumb PO [me]
TR6oldtimer
Some time back I put a TR250 engine into my '73 to replace the tired original with the intent of rebuilding the six engine later. Well that engine was to expensive to rebuild, so I did the 250 which is now done. Apparently, some time in the past I replaced the 250 water pump, with a narrow pulley water pump for a TR6. After all the work getting the engine fresh, and everything back on, it was not until I went to put the fan belt on that I noticed it was the wrong pump. Now I know I had the old pump, so I looked everywhere for it. I did find a second pump for the six. In my mind, I remember I saw the 250 pump, but for the life of me, I cannot find it now.
I asked myself, "Self, did you really have a 250 pump?" So I looked at the pictures before I ripped everything apart, and low and behold, there on the engine was that TR6 pump, with the belt riding high, dah, what an idiot I was. Drat, that means I swapped the pump 15 years ago. Still, I thought I saw it just a couple of years ago.
<span style="font-weight: bold">But WAIT, the 250 had the narrow pulley</span>, the '73 had the wide pulley, yet the alternator and crankshaft pulley on the 250 engine are wide. So it appears, when I did the 250 engine swap years ago, I used the damper pulley off the six to match the wide pulley on the alternator, but installed a 250 water pump.
Low and behold, there on the six engine is the narrow damper pulley that should have been on the 250. (which explains why my six had no timing marks, yet the 250 did).
Oh, I also found out that the narrow damper pulley is about 3/4 of an inch less in diameter then the six, which means the water pump and alternator would have spun slower on the 250 then on the six.
So, what to do? Buy a wide pulley water pump and get on with life, or buy a narrow pulley for the alternator and use the smaller 250 damper pulley?
I know the answer, buy the wide pulley water pump. But then again...
So, how is the quality of the water pumps now being peddled, and are the wide pulley pumps only available with the ugly double pulleys?
Getting old is tiresome.
RAY, hope not too may more post like that. I needed a flow chart to keep track
Don, yes, way to much coffee this morning.
What does your gut tell you to do? Then listen to your wife. I would say get the right stuff so you don't have to remember what you did. If it is a 250 engine then get the stuff for a 250. Keep it simple in the long run.
If you ever sold the car you could say it is a tr6 with a rebuilt 250 engine and then the new owner can buy the parts correctly.
Just a thought, Ray, perhaps there was a reason they went to that wider belt? It seems an odd thing to change, unless there was a specific problem being addressed.
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
9 SOLD!! Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
T For Sale Triumph tr6 early tonneau cover - $250.00 Triumph Classifieds 0
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
KVH General TR Best Year for TR6; Preferred over TR250? Triumph 11
tr6nitjulius TR6 TR6/250 & Healeys Drive 'em! Triumph 0
T TR6 TR250/TR6 - Improving hand brake mech advantage Triumph 11
JodyFKerr TR6 TR250 / TR6 Parts catalogs Triumph 1
glemon TR6 TR250/early TR6 v. late TR6 Different Speedo Ratio Triumph 4
K TR6 TR250/4 top on a TR6? Triumph 11
glemon TR6 obscure tr250 tr6 seat rail question Triumph 4
glemon TR6 TR250 TR6 no oil pressure after rebuild Triumph 20
glemon TR6 TR250 TR6 Rear Springs Triumph 13
KVH TR6 TR4A/TR250/TR6 Triumph 5
TR6oldtimer TR6 TR250-TR6 flywheels Triumph 6
toysrrus TR6 "For Sale": TR2, 3, 4, 250 & TR6 Books and Manuals Triumph 2
T TR6 TR4/TR5/TR6/TR250 parts still available Triumph 4
glemon TR6 TR250/TR6 Engine Rebuild Question Triumph 7
heliguy TR6 TR250/TR6 shifter assy Triumph 2
jjbunn TR6 TR250 Ignition Switch in my TR6 Triumph 13
G TR6 Need a part from an early TR6/250 Triumph 9
C TR6 TR6, TR250/5 Frame Dimensions...Who has them? Triumph 3
T TR6 TR250 engine or TR6 ? Triumph 8
G TR6 Need help on tr6/250 top install Triumph 4
V TR6 two piece valve spring retainers on tr6 and 250. Triumph 1
LastDeadLast TR6 Question about TR6/250 hubs Triumph 4
G TR6 Interest in TR6/250 Ansa exhaust Triumph 3
J TR6 1975 TR6 Convertible Top Replacement. Triumph 1
mctriumph For Sale Tr6 rear bumper assembly/with over ride bar Triumph Classifieds 0
E TR6 TR6 Front fenders Triumph 5
EWD TR6 74 TR6 headscratcher Triumph 38
jfarris For Sale TR6 Yellow Fan - New Triumph Classifieds 0
tr6nitjulius TR6 TR6 review Triumph 3
K TR2/3/3A First gear ratio on the TR6 gearbox? Triumph 11
D Wanted TR6 Lamp/Bezel Assembly - Heater Controls - 219139 Triumph Classifieds 1
mctriumph Wanted Tr 3/Tr6 transmission kit interest Triumph Classifieds 2
tr6nitjulius For Sale SOLD! 8/29/24: 4$ale NEW! TR6 radiator support brackets Triumph Classifieds 0
T TR6 TR6 distributor issue Triumph 6
tr6nitjulius TR6 TR6 N IT That SOUND FEEL LOOK! Triumph 0
K For Sale 1974 TR6 For Sale Triumph Classifieds 0
B For Sale TR6 parts for sale Triumph Classifieds 0
T TR6 TR6 blower motor and fuel gauge won't work Triumph 10
B For Sale Lifting & Bracing Frame Kit TR4-TR6 Triumph Classifieds 0
