T
TRDejaVu
The barn find engine is going back together. My M.O. is to get it running so I can check out the whole drivetrain before winter. Then if anything I don't know about needs doing, that will be the time. I have replaced the rings and con-rod bearings, but I anticipate doing a proper engine overhaul in a year or 2.
I am ready to put on the "new" head (it came without one). The top surface of a couple of liners have some pitting, as does a couple of place on the top of the block. Is there any sort of epoxy, or similar, that is strong and resistant enough that can can be used to smooth these out?
Thanks.
Thanks.
