TR4/4A TR4 Choke Cable Routing
jimitro
What is the proper routing for the choke cable? Does it go through the bulkhead hole under the hood catch or there's another hole just above the solenoid? Also, does the the cable route up over the rear carb and down or should it be routed under the carbs to jet lever?
I cannot remember how the original was when I dismantled it.
Thanks
You should probably specify whether you have SUs or Stromberg carbs -- though since you say 'to jet lever' it sounds like SUs and I cannot help.
