59triumphtr3a
Hello, I peeked inside my 3A long nose starter today. On the brush end, I found a piece of paper in there. It wraps almost all the way around the inside of the yoke. I am curious as what is it for and how should it fit? It was slightly wedged behind the field coils a bit but yet not so far as to partially block the two openings through which you see the brushes. I'm sure it vibrated around from its original installation until the stuck the way I found it. It is almost the same width of the brush cover band. Also, does anybody have 'I wish I knew that before I started' tips to share on restoring one of these beasts?
Thanks,
Thanks,
Hi Guest!
