angelfj1
Last night I finished converting the 250 to silicone brake fluid. This involved replacing the master cyl., flexible hoses, rear wheel cylinders and some of the smaller brake lines. I did not remove and split the calipers. The lines which were not replaced, were left in place, but flushed with brake cleaner. I did this by using the little "straw" that come stuck to the side of the aerosol can, and squirting fluid into the lines. This was repeated until the fluid ran clear and followed by blowing shop air through the line. Re-filling the system was fairly routine, except I found one leak at a brakeline - hose junction. Bleeding was also routine, and once the lines filled, I was able to get most of the air bled out. I will now let the car sit for a few days and re-bleed. I also drained and flushed the clutch master, lines and slave cylinder. But after re-filling with silicone and bleeding, I was not able to get much slave cylinder motion. (how far should the slave cylinder linkage travel?) I repeated this several times to no avail. To complicate matters, the very small capacity of the clutch master required me to stop and refill it - a real pain. I don't understand the problem. I had a clutch before changing to silicone and now I don't. The only sympton that I noticed was that the old Dot 3 fluid was black when I flushed the lines. Help!!! :frown:
