doc50
I have a common problem I've tried to fix to no avail. I always need to kick the throttle down, usually a couple times in quick succession to idle down from 1200 or even higher. I've put a heavier return spring at the bulkhead, increased axial spring tension at the butterfly rods on the carbs, oiled and greased everything. Nothing seems to help.
That jus cain't be normal....
ISTR someone (Randall, was that you?) having a cure, maybe something as simple as adjusting geometry of the assy to certain angles relative to each other?
Thanks for any sage advice.
Thom
1959 TR3
#TS34909L(O)
Thom
1959 TR3
#TS34909L(O)
Hi Guest!
