AKA "Experiments in Operating Temps" or "No no no, don't touch that."Having fooled with a possible vapor lock problem, and not found that to be the issue, I became side-tracked with an amusing study. Using my trusty laser-guided infra-red thermometer gun, I thought I'd record some temps related to my 1275 (with dual HS2s). Curious? Of course you are. :cooler:
So, I let the engine reach normal operating temperature (though it was cold outside - maybe 45F), and then I collected the following values for a stationary car in the garage. Most values varied a bit (but the range wasn't significant), and all are Fahrenheit... and I probably could have let the car warm up a tad more (though I believe the temp gauge read about 175).
Exhaust header pipes = 530 (though at the head closer to 550)
Exhaust pipe = 260, half way back (under driver seat)
Muffler = 285
Tail-pipe = 60 (it was cold outside)
Engine Block = 167 header side, 144 passenger side
Sump = 148
Rocker Cover = 93
Carb Heat Shield = 123 (with header below it)
Carbs = 90s?... but variable depending on where
Radiator Top = 126
Useful? Absolutely not, but fun. So, for all the kids out there, don't touch the exhaust system.
